Conveniently positioned at the front of your PC, this SuperSpeed six slot USB 3.0 card reader accepts all popular cards in a single location. Includes a USB 3.0 port for extra connectivity. Easy to install. Choice of black or classic-white front fascia panels.
- Up to ten times faster than USB 2.0
 - Accepts all popular memory cards
 - SDXC compatible
 - For 3.5" PC front bay
Specification
- Application 3.5" PC bay
 - Memory card slots 6
 - Memory card types Compact Flash (CF I, CF II, Ultra, Extreme, I-Pro, Ultimate, MD) / Memory Stick (MS Pro, MS Pro Duo, Magic Gate, Extreme, Ultra) / Secure Digital (SDXC, SDHC, SD, Ultra, Extreme, Elite Pro, High Speed, MMC, MMC Mobile) / - 64GByte for SDXC - 32GByte for SDHC / Extreme Digital (X card, Type H, Type M) / M2 (Memory Stick Micro M2) / microSD (microSDHC, High Capacity)
 - Interface USB 3.0 (2.0/1.1 compatible)
 - Data transfer rate 5Gb/s (USB 3.0)
 - LED indication Power On, Card In & Data Transfer
 - PC connection two USB 3.0 type A connectors
 - Supported OS Windows 2000 / XP / VISTA / 7
 - Plug & Play Supported
 - Akasa AK-ICR-13 - card reader - USB 3.0
- Product Type
 - Card reader - internal - 6 in 1
- Supported Memory Cards
 - CompactFlash Card type I, CompactFlash Card type II, Memory Stick, Memory Stick PRO, MultiMediaCard, SD Memory Card, Memory Stick Duo, Memory Stick PRO Duo, MultiMediaCardmobile, microSD, SDHC Memory Card, Memory Stick Micro (M2), microSDHC, SDXC Memory Card
- Host Interface
 - USB 3.0
- Required Bay
 - 3.5" internal
 - Status indicator
- Product Type
- Host Interface
 - USB 3.0
- Required Bay
 - 3.5" internal
 - Status indicator
Memory Card
- Capacity
 - (max)
- Additional Ports
 - 1 x USB 3.0
- OS Required
 - Microsoft Windows 2000/XP/Vista/7
- Included Accessories
 - Black front panel, white front panel
 - Plug and Play
