Akasa USB 3.0 Multi Memory Card Reader, 5 Active Slots - Black
Quicklinx: 8DW6WS00 Mfr#: AK-CR-05U3BK
  • Ultra compact modern design
  • Five card-slots are active at the same time, allowing cross format data transfer
  • Windows 2000 / XP / Vista / 7 / 8 / 8.1 (supports USB 3.0), Mac OS X 10.3 or higher (supports USB 2.0)
Akasa AK-CR-05U3 - card reader - USB 3.0
Card reader - external
Supported Memory Cards
CompactFlash Card type I, CompactFlash Card type II, Memory Stick, Memory Stick PRO, MultiMediaCard, SD Memory Card, Memory Stick Duo, xD-Picture Card, TransFlash, MultiMediaCardmobile, microSD, SDHC Memory Card, Memory Stick Micro (M2), microSDHC, xD-Picture Card Type H, xD-Picture Card Type M, SDXC Memory Card
Host Interface
USB 3.0
Host Interface
USB 3.0
84 mm
48.5 mm
14 mm
Memory Card
(max)
Apple MacOS X 10.3 or later, Microsoft Windows 2000/XP/Vista/7
USB cable
Plug and Play
