- Ultra compact modern design
- Five card-slots are active at the same time, allowing cross format data transfer
- Windows 2000 / XP / Vista / 7 / 8 / 8.1 (supports USB 3.0), Mac OS X 10.3 or higher (supports USB 2.0)
- Akasa AK-CR-05U3 - card reader - USB 3.0
- Product Type
- Card reader - external
- Supported Memory Cards
- CompactFlash Card type I, CompactFlash Card type II, Memory Stick, Memory Stick PRO, MultiMediaCard, SD Memory Card, Memory Stick Duo, xD-Picture Card, TransFlash, MultiMediaCardmobile, microSD, SDHC Memory Card, Memory Stick Micro (M2), microSDHC, xD-Picture Card Type H, xD-Picture Card Type M, SDXC Memory Card
- Host Interface
- USB 3.0
- Black
- Product Type
- Host Interface
- USB 3.0
- Black
- 84 mm
- 48.5 mm
- 14 mm
Memory Card
- Capacity
- (max)
- OS Required
- Apple MacOS X 10.3 or later, Microsoft Windows 2000/XP/Vista/7
- Included Accessories
- USB cable
- Plug and Play
