- Stylish brushed aluminium finish
- Supports SDHC / SDXC and new UHS-II standard
- Four card-slots are active at the same time, allowing cross format data transfer
- Windows XP / Vista / 7 / 8.X / 10 (supports USB 3.0) Mac OS X 10.3 or higher (supports USB 2.0)
- Akasa card reader - USB 3.0
- Product Type
- Card reader - external
- Supported Memory Cards
- CompactFlash Card type I, CompactFlash Card type II, Memory Stick, Memory Stick PRO, Microdrive, MultiMediaCard, SD Memory Card, Memory Stick PRO Duo, MultiMediaCardmobile, microSD, SDHC Memory Card, microSDHC, SDXC Memory Card, microSDXC, SDHC UHS-II Memory Card, SDXC UHS-II Memory Card
- Host Interface
- USB 3.0
- Brushed aluminum
- Product Type
- Host Interface
- USB 3.0
- Brushed aluminum
- 5.6 cm
- 8 cm
- 1.8 cm
Memory Card
- Capacity
- (max)
- Required Ports
- 1 x 10 pin Micro-USB Type B
- OS Required
- Apple MacOS X 10.3 or later, Microsoft Windows XP / Vista / 7 / 8 / 8.1 / 10
- Included Accessories
- USB 3.0 cable
- Plug and Play
