AK-675 is a low-noise and high performance value cooler. AK-450 hi-performance thermal compound is pre-applied. New production technology has produced this high performance cost effective cooler.
- Akasa AK 675 - processor cooler
- Product Type
- Processor cooler
- Compatibility
- Socket 478
- Fan Diameter
- 80 mm
- Fan Height
- 25 mm
- Rotation Speed
- 2400 rpm
- Air Flow
- 38.4 cfm
- Noise Level
- 26 dBA
- Product Type
- Processor cooler
Heatsink & Fan
- Compatible With
- Socket 478
- Processor Compatibility
- Pentium 4 - up to 2.8 GHz
- Heatsink Dimensions
- 83 mm x 80 mm x 50 mm
- Fan Diameter
- 80 mm
- Fan Height
- 25 mm
- Rotation Speed
- 2400 rpm
- Air Flow
- 38.4 cfm
- Noise Level
- 26 dBA
Customer reviews
Write a review for the Akasa S478 3.4GHz Lo-Noise Fan here!
Not that Lo-Noise
Reviewed by Anonymous Review Posted 28/03/2007
If you want a quieter pc then look elseware.. This cooler is not quiet at all, certainly not the stated 26db.. I gave it a try because it had an 80mm fan which meant that it probably would be quiet but the fan spins at 3300rpm so its actually quite loud.. I amd going to try an alternate fan because the heatsink itself looks quite good and its holding my CPU at about 39deg.. Of course the quieter fan may not provide enough airflow to ceep the cpu cool.. If you want a cheap cooler this one is for you, if you want a quiet one keep looking..
- Overall
- Ease of use
- Value for money
The opinions expressed in this reviews section are those of our customers and not of BT Business Direct. Nothing contained herein amends BT Business Direct’s terms and conditions.
