Quasar: Widescreen notebook cooler
20cm fan delivers ultra-cooling performance, ergonomic design provides comfortable keyboard operation.
- Powered directly from your notebook
- Strong, stylish ventilated body enhances heat dissipation
- Adjustable fan speed for quiet or performance
- Suitable for 17" widescreen or below
Specification
- Application 17" - 15.6" Notebooks / MacBooks
- Material ABS structure with mesh face panel
- Outline dimension 380 x 322 x 50mm
- Fan dimension 200 x 200 x 20mm
- Fan speed High speed 800 RPM, low speed 500 RPM
- Fan air flow 63.7 CFM
- Fan air pressure 0.44mm H2O
- Voltage rating 5V DC
- USB cable 600mm
- Weight 710g
- Available colours Black
- Akasa AK NBC-32 Quasar - notebook fan
- Product Type
- Notebook fan
- Package Content
- USB cable
- Black
- Fan Diameter
- 200 mm
- Fan Height
- 20 mm
- Rotation Speed
- 500/800 rpm
- Air Flow
- 63.7 cfm
- Rated Voltage
- 5 V
- 38 cm x 32.2 cm x 5 cm
- 0.71 kg
- Notebook Compatibility
- 17"
- Mesh top panel
- Product Type
- Notebook fan
- Package Content
- USB cable
- 38 cm
- 32.2 cm
- 5 cm
- 0.71 kg
- 17"
- Black
Heatsink & Fan
- Fan Diameter
- 200 mm
- Fan Height
- 20 mm
- Rotation Speed
- 500/800 rpm
- Air Flow
- 63.7 cfm
- Air Pressure
- 0.44 mm
- Rated Voltage
- 5 V
- Mesh top panel
