Akasa Newton X Fanless Solid Aluminium Case for NUC - Support 2.5" SATA HDD / SSD
Quicklinx: 9KWGWS00 Mfr#: A-NUC09-A1B06U
Newton X fanless case for IntelĀ® NUC support 2.5" SATA HDD / SSD
  • Aluminium fanless CPU cooling design
  • Ideal for business, education and embedded environments
  • Stylish front panel diamond edge finish
  • Support IR function
  • Compatible with the following IntelĀ® NUC motherboard: D54250WYB / D34010WYB
  • Suitable for VESA mounting
  • USB 3.0 port & Support IR remote function
  • Antenna fitting holes
  • Kensington lock
  • Totally silent fanless CPU cooling design
Spec
  • Material Aluminium
  • Motherboards types UCFF 4" X 4"
  • Dimensions 150 x 185 x 47mm (W x D x H)
  • Weight 1270 g
  • Drive bays 2.5" SSD/HDD
  • Front I/O Power button, power and HDD led, USB 3.0 port x 2, IR receiver opening, HD Audio in / out
  • Antenna fitting holes 2
  • Security Kensington lock
  • VESA mounting Support
  • Product code A-NUC09-A1B
