Newton Fanless case for NUC systems
- Aluminium fanless CPU cooling design
- Ideal for business, education and embedded environments
- Form factor: UCFF 4" X 4"
- Suitable for VESA mounting
- Antenna fitting holes
- Kensington lock
- Compatible with the following NUC motherboard: Intel DCP847SK / Intel D33217GKE
Spec
- Material Aluminium
- Motherboards types UCFF 4" X 4"
- Dimensions 150 x 150 x 47mm (W x D x H)
- Weight 925 g
- Antenna fitting holes 2
- Security Kensington lock
- VESA mounting Support
- Akasa Newton - USFF - mini ITX
- Product Type
- System cabinet
- Form Factor
- Ultra small form factor
- Black
- I/O Connectors
- 1 x USB 2.0
- Supported Motherboards
- Mini-ITX
- System Cabinet Features
- VESA mounting interface, Kensington lock support, aerial fitting holes
- Power Device
- No power supply
- 15 cm x 15 cm x 4.7 cm
- 925 g
- Form Factor
- Max Mainboard Size
- Mini ITX
- Mini-ITX
- Product Material
- Aluminium
- Black
- 1 x USB 2.0
- Included Accessories
- Thumbscrews, thermal paste
- Power Device
- No power supply
- 15 cm
- 15 cm
- 4.7 cm
- 925 g
