- Socket type: Intel LGA775, LGA115X & LGA1366
- AMD Socket: AM2, AM2+, AM3, AM3+, FM1 & FM2
- Heatsink material: Aluminium fins, copper heatpipes
- Cooler weight: 282g
- Cooler dimension: 120 x 120 x 57mm (W x D x H)
- Fan dimension: 120 x 120 x 15mm
- Fan speed: 600 - 1800 RPM
- Max airflow: 61.37 CFM
- Max air pressure: 1.72 mm H²O
- Noise level: 32.9 dB(A)
- Voltage rating: 12V DC
- Bearing type: EBR
- Fan connector: 4pin PWM
- Product code: AK-CC4016EP01
- Akasa NERO LX 2 - processor cooler
- Product Type
- Processor cooler
- Package Content
- Washer, Heat Conduction Compound, screws, Intel mounting bracket, 5 rubber pads, bracket screws, spanner, AMD mounting bracket
- Compatibility
- LGA775 Socket, LGA1156 Socket, Socket AM2, Socket AM2+, LGA1366 Socket, Socket AM3, LGA1155 Socket, Socket AM3+, Socket FM1, Socket FM2, LGA1150 Socket
- Heatsink Material
- Aluminium and copper
- Fan Diameter
- 120 mm
- Fan Height
- 15 mm
- Rotation Speed
- 600-1800 rpm
- Air Flow
- 61.37 cfm
- Noise Level
- 32.9 dBA
- Power Connector
- 4-pin fan connector
- Rated Voltage
- 12 V
- 4 copper heatpipes
- 12 cm x 12 cm x 5.7 cm
- 282 g
- Product Type
- Processor cooler
- Package Content
- 12 cm
- 12 cm
- 5.7 cm
- 282 g
Heatsink & Fan
- Compatible With
- Heatsink Material
- Fan Diameter
- 120 mm
- Fan Height
- 15 mm
- Rotation Speed
- 600-1800 rpm
- Air Flow
- 61.37 cfm
- Air Pressure
- 1.72 mm
- Noise Level
- 32.9 dBA
- Power Connector
- Rated Voltage
- 12 V
