Akasa Intel 2U all copper active cooler for LGA2011 w/70mm PWM fa
Quicklinx: 99T8WS00 Mfr#: AK-CC6502BP01
2U chassis server cooling solution for Intel LGA2011 motherboards. Copper heatsink designed for rackmount or workstations chassis. Long life PWM fan provides acurate cooling. Pre-applied spring-loaded screws and motherboard backplate guarantee safe retention.
  • Active LGA2011 cooling solution for 2U chassis
  • 7cm fan with automatic PWM speed control
  • Solid copper heatsink
  • Reliable and long life twin ball bearing
Akasa AK CC6502BP01 - processor cooler
Processor cooler
Package Content
Thermal grease
Compatibility
LGA2011 Socket
Heatsink Material
Copper
Fan Diameter
70 mm
Fan Height
15 mm
Fan Bearing
Twin Ball Bearing
Rotation Speed
1000-5000 rpm
Air Flow
37.2 cfm
Noise Level
42.4 dBA
Power Connector
4-pin fan connector
Rated Voltage
12 V
Pulse-width modulation (PWM) support
9 cm x 8.9 cm x 4.25 cm
582 g
Processor cooler
Package Content
Thermal grease
9 cm
8.9 cm
4.25 cm
582 g
Heatsink & Fan
Compatible With
LGA2011 Socket
Heatsink Material
Copper
Fan Diameter
70 mm
Fan Height
15 mm
Fan Bearing
Twin Ball Bearing
Rotation Speed
1000-5000 rpm
Air Flow
37.2 cfm
Air Pressure
6.015 mm
Noise Level
42.4 dBA
Power Connector
4-pin fan connector
Rated Voltage
12 V
Mounting Kit
Included
MTBF
65,000 hour(s)
