Akasa Integral P2SATA Quad Interface Combo Enclosure for IDE and SATA HDD
Customer rating: 4.0* (Write a review)
Quicklinx: 4QTNWS00 Mfr#: AK-ENP2SATAV2-BK
Integral E-SATA HDD enclosure is a quad interface (dual interface/dual transfer) combo enclosure with speeds up to 3.0 Gbit/s. The Integral is designed for 3.5 inch IDE PATA and SATA HDD drives. eSATA or USB 2.0 transfer is switchable. Dual HDD interfaces in one enclosure brings a greater convenience in data storage management. Sleek aluminium body enables efficient heat dissipation. Stylish blue LED power and access indicator. Easily stackable providing smart use of space. Be smart, be Integral.
  • Easy to install
  • Supports 3.5" IDE and SATA drives
  • E-SATA transfer speeds up to 3.0Gb/s
  • E-SATA or USB 2.0 transfer switchable
  • Sleek aluminium case for efficient heat dissipation
  • Easy stack design for smart use of space
  • Blue LED power and access indicator
  • Plug and Play
  • OS Support Win 2000/XP/VISTA/7, Mac OS 9 / OS X
  • Interface eSATA and USB 2.0 (1.1 compatible)
  • USB Data Transfer Rate 480 Mb/s (max)
  • eSATA Data Transfer Rate 3.0 Gb/s (max)
  • Material Aluminium
  • Power & Access Indicator Blue LED
  • DC input 5V , 12V DC (power adapter)
  • Supported OS Windows 2000/XP/Vista/7
  • Mac Os 9 and OS X
  • Plug & Play
  • Dimensions 218 x 123 x 33 mm
Manufacturer
Akasa
Product Line
Akasa Integral P2 E-SATA
Model
AK-ENP2SATA-BKU
Customer reviews
Write a review for the Akasa Integral P2SATA Quad Interface Combo Enclosure for IDE and SATA HDD here!
Very Good
Reviewed by A N L. Review Posted 25/07/2008
Just bought 4 of these (1 DOA and needs replacing) to replace the netgear caddies that had fallen off my network a refuse to re-attach. If you are going to stack these as is suggested I would suggest getting some thicker stick on rubber feet to space them further apart as they do run hot, and this will allow more air around them. Otherwise no complaints!
  • Overall 5*
  • Ease of use 4*
  • Value for money 5*
Excellent piece of kit
Reviewed by Mal. Review Posted 10/07/2008
If you have a largish capacity 3.5" SATA drive lying around, perhaps from an unused desktop, then you should seriously consider buying this piece of kit. It turns a redundant SATA internal drive into a bostin' external drive for your laptop. Very well made, easy to set up and with USB2 gives a respectable data transfer rate - I'm getting approx 13MB/sec using XP which is enough to capture DV video straight to disc. Also uses an ESATA interface if you have one available. Only drawback is that this is not a particularly portable item, it's quite chunky and uses an external power supply. Oh, and the tiny rubber feet are prone to coming off.
  • Overall 5*
  • Ease of use 5*
Sweet eSata & USB Enclosure
Reviewed by JS. Review Posted 06/12/2007
I'm a bit of an 'enclosure junkie' - as these are essential items in my line of work. This is the best I've used yet... rock solid build quality (solid aluminium), silent and cool running. Choices of connectivity... SATA Drive > eSata or USB 2 IDE PATA Drive > USB 2 Speed when connected to an eSata connection is superb and works well under XP/Vista - will test with Ubuntu later and report back. Only small issue is the skinny cable that lights up the front of the case - I found it best to disconnect until you've installed the drive and almost closed the case, before reconnecting... thus avoiding any snagging/nipping of the cable. Looks smart, feels solid and weighty, performs really well - seems like a good buy (just as well - I took a chance and ordered two!).
  • Overall 5*
  • Ease of use 4*
Read all 5 customer reviews
The opinions expressed in this reviews section are those of our customers and not of BT Business Direct. Nothing contained herein amends BT Business Direct’s terms and conditions.
