Akasa Integral P2 2.5" eSATA/USB External Storage Enclosure
Customer rating: 5.0* (Write a review)
Quicklinx: 4THSWS00 Mfr#: AK-ENP2NES-BK
This aluminum enclosure is compact and light, perfect for the mobile lifestyle. The sleek aluminum body enables efficient heat dissipation. Blue LED power and access indicator gives it a touch of real style.
This external enclosure enables you to connect to both legacy and new PC technology. So investment in technology is not lost.
Akasa Integral P2 AK-ENP2NES-BK - storage enclosure - SATA 3Gb/s - eSATA 3Gb/s, USB 2.0
Storage enclosure - external
Bus Type
Expansion Bays
1 x internal - 2.5"
Hard Drive Form Factor Compatibility
2.5"
SATA 3Gb/s
Data Transfer Rate
3 Gbit/s
Supported Devices
Hard drive
Product Material
Aluminium
Power Source
USB bus
Microsoft Windows 2000, Apple MacOS 9.0 or later, Microsoft Windows XP, Microsoft Windows Vista
8 cm x 15.1 cm x 1.6 cm
2.5"
Host Bus
Product Material
Aluminium
Storage Controller
SATA 3Gb/s
Data Transfer Rate
3 Gbit/s
Supported Devices
Hard drive
Bays
1 x internal - 2.5"
1 x SATA 3Gb/s - SATA (internal)
1 x USB 2.0 - 4 pin USB Type A , 1 storage - eSATA-300 - 7 pin external Serial ATA
Carrying case, USB (power) cable
1 x USB cable , 1 x eSATA cable
Mounting Kit
Included
Plug and Play
Power Source
USB bus
8 cm
15.1 cm
1.6 cm
Customer reviews
Write a review for the Akasa Integral P2 2.5" eSATA/USB External Storage Enclosure here!
Great drive enclosure
Reviewed by Ian. Review Posted 27/02/2009
This must be one of the best 2.5" caddies. Internally you can install either an IDE or SATA drive. Externally you can connect it to your computer with either USB or eSATA (note you can only use USB with an IDE drive).
The unit comes with the following cables:
1) USB cable to power the unit
2) USB data cable
3) eSata to eSata data cable
It's very easy to install and set up and it comes with a nice soft carry case.
I installed a 320GB Western Digital SATA drive for a great backup/portable drive setup.
All in all highly recommended.
  • Overall 5*
  • Ease of use 5*
  • Value for money 5*
The opinions expressed in this reviews section are those of our customers and not of BT Business Direct. Nothing contained herein amends BT Business Direct’s terms and conditions.
