Euler M fanless case for Mini-ITX IntelĀ® 4th Generation (Haswell) motherboards
- Aluminium fanless CPU cooling design
- Stylish front panel diamond edge finish
- Support four 2.5" drive bays
- DC to DC internal power adapter
- Optional 80W external power adapter
- Compatible motherboard -
- Asus Z97I-PLUS / Asus H97I-PLUS / Gigabyte GA-Z97N-WIFI / Asrock Z97E-ITX/AC
Specification
- Material Aluminium with anodized black
- Panel material Aluminium
- Motherboards types Mini-ITX boards without DC onboard
- Dimensions 245 x 274.5 x 68.5mm (WxDxH)
- Internal bays 4 (for 2.5" HDD)
- Security Kensington lock
- VESA mounting Support
- Front panel USB 3.0 ports 2
- Internal DC converter 12V to 3.3V, 5V, 5VSB and -12V
- External AC power adapter 80W
- Power connectors 24pin motherboard
- 4pin ATX12V
- 4pin Molex
- SATA power
