- Classic and stylish
- Black brushed aluminium cover
- Energy-saving on/off switch design
- Connection for up to ten USB 3.0 device
- Plug & Play and Hot-Swappable
- Up to 5Gbps data transfer and backward compatible with USB 2.0
- USB charging port provide up to 2.4A each
- Charging port support smart phone or tablet fast charging
- High performance USB fast charging controller provide auto detect and charging
- Meet USB battery charging specification
- Akasa Elite 10EX - hub - 10 ports
- Hub - 10 ports
- Subtype
- USB
- Ports
- 10 x SuperSpeed USB 3.0
- USB 1.1, USB 2.0, USB 3.0
- Power
- AC 120/230 V
- 14.05 cm x 7.2 cm x 2.5 cm
- Black
- System Requirements
- Apple MacOS X 10.3 or later, Microsoft Windows XP / Vista / 7 / 8 / 10
- Localisation
- United Kingdom
- Hub - 10 ports
- Enclosure Type
- Desktop
- Subtype
- USB
- Ports
- 8 x USB 3.0 Type A , 2 x USB 3.0 Type A 2.4A charging port , 1 x USB 3.0 Type B
- Power Device
- External power adapter
- Voltage Required
- AC 120/230 V
- Black
- Cables Included
- 1 x SuperSpeed USB cable
- Plug and Play
- Localisation
- United Kingdom
- OS Required
- 14.05 cm
- 7.2 cm
- 2.5 cm
