Akasa DuoDock 2 USB/ESATA Desktop Dock (2.5" & 3.5")
Quicklinx: 775JWS00 Mfr#: AK-DK02-UK
Note: To access both drives simultaneously over eSATA, please ensure your eSATA port supports a multiplier feature
DuoDock 2 is a two slot SATA hard drive docking station offering much greater flexibility than traditional external enclosures. It can take two drives simultaneously and is designed to sit on your desk enabling you to quickly read and write data to SATA drives. Simply place a drive (or two) into the Duo Dock 2 and off you go! Make use of your spare SATA hard drives both 2.5" notebook or 3.5" desktop (all capacities).
Chose you favorite PC connection: USB provides universal support and full hot swapping feature; eSATA delivers blazingly fast data transfer up to 3.0 Gb/s. Blue LED base with on/off switch can provide stylish illumination.
  • Simple connection for 2.5" and 3.5" SATA and SSD drives
  • Takes two hard drives simultaneously
  • Choose your connection: eSATA or USB 2.0
  • Stylish blue LED base illumination with on/off switch
