The ultra quiet AK-CCE-7101CP uses a high engineering omni directional heatsink providing efficient CPU and motherboard zone cooling. The fan uses Intel approved power management (PWM) where speed is regulated automatically by CPU usage. Under normal conditions the CPU fan speed is low ensuring low noise computing.
AK-CCE-7101CP is designed to work with CPU's up to 95 W but greater cooling efficiency can be attained with efficient case airflow. Pre-applied high performance thermal compound ensures clean and easy installation.
- Akasa AK CCE-7101CP - processor cooler
- Product Type
- Processor cooler
- Package Content
- Thermal paste
- Compatibility
- LGA775 Socket, LGA1156 Socket, LGA1155 Socket
- Heatsink Material
- Aluminium
- Fan Diameter
- 92 mm
- Fan Height
- 25 mm
- Fan Bearing
- Ball bearing
- Rotation Speed
- 600-3000 rpm
- Air Flow
- 55.4 cfm
- Noise Level
- 11.7 - 28.8 dBA
- Power Connector
- 4-pin fan connector
- Rated Voltage
- 12 V
- Pulse-width modulation (PWM) support
- 9.5 cm x 9.5 cm x 6.3 cm
- 362 g
- Product Type
- Processor cooler
- Package Content
- Thermal paste
- 9.5 cm
- 9.5 cm
- 6.3 cm
- 362 g
Heatsink & Fan
- Compatible With
- Processor Compatibility
- Pentium 4 , Core 2 Duo , Core 2 Quad , Core i3 , Core i5 , Core i7
- Heatsink Material
- Aluminium
- Fan Diameter
- 92 mm
- Fan Height
- 25 mm
- Fan Bearing
- Ball bearing
- Rotation Speed
- 600-3000 rpm
- Air Flow
- 55.4 cfm
- Air Pressure
- 4.3 mm
- Noise Level
- 11.7 - 28.8 dBA
- Power Connector
- Rated Voltage
- 12 V
- Rated Current
- 0.26 A
- Mounting Kit
- Included
- MTBF
- 40,000 hour(s)
