Akasa Dual 2.5" SSD/HDD mounting module for 3.5" Bay, Black aluminium
Quicklinx: 634CWS00 Mfr#: AK-MX010V2
Mounting kit AK-MX010 allows two notebook drives to fit into a standard 3.5" drive bay of the PC case. Introduce technology high-speed SSD (solid state drives) or make use of laptop HDD in your PC. High-grade aluminum enables rapid heat dissipation.
Akasa AK-MX010 - storage bay adapter
Storage bay adapter
Supported Form Factor
3.5" to 2.5"
Expansion Bays
2 x internal - 2.5"
Compatible Bay
1 3.5"
Product Material
Aluminium
10.1 cm x 11.4 cm x 2.4 cm
145 g
Storage bay adapter
3.5" to 2.5"
Product Material
Aluminium
Storage Controller
No CPU
Bays
2 x internal - 2.5"
Compatible Bay
1 x internal 3.5"
Mounting Kit
Included
10.1 cm
11.4 cm
2.4 cm
145 g
