Akasa Dual 2.5" SDD/HDD Mounting Module For 3.5" Bay
Quicklinx: 7TGKWS00 Mfr#: AK-HDA-03
Mounting adapter allows a 2.5" SSD or HDD to fit into a 3.5" PC drive bay.
  • Application Fits two notebook drives into PC case
  • Designed for 2 x 9.5mm HDD or
  • 1 x 9.5mm HDD & 1 x 12.5mm HDD on top
  • Material Black SECC
  • Dimensions 113(L) x 102(W) x 25(H) mm
Akasa AK-HDA-03 - storage bay adapter
Storage bay adapter
Supported Form Factor
3.5" to 2.5"
Expansion Bays
2 x internal - 2.5"
Compatible Bay
1 3.5"
10.2 cm x 11.3 cm x 2.5 cm
Storage bay adapter
3.5" to 2.5"
Storage Controller
No CPU
Bays
2 x internal - 2.5"
Compatible Bay
1 x internal 3.5"
10.2 cm
11.3 cm
2.5 cm
