Akasa Crypto X1 Compact Mini ITX Case with Internal 200W Power Supply
Quicklinx: 9ZXKWS00 Mfr#: A-ITX11-M1B20U
  • Ideal for business education and embedded environments
  • Form factor: Mini-ITX 6.7" X 6.7"
  • Bays: 2.5 HDD and slimline optical drive
  • Audio and two USB ports for easy connectivity
  • Compatible with all Mini-ITX motherboards
  • Flex ATX power supply (optional)
  • Motherboard support: Mini-ITX- Body material: Steel- External bays: 1 x 5.25" (for slim optical drive)
  • Internal bays: 1 (for 2.5 HDD)
  • Dimensions: 200(W) x 306(D) x 76(H)mm
  • I/O ports: 2 x USB 2.0 1 x HD audio (AC97 compatible)
  • PSU support: Flex ATX power supply
Akasa Crypto X1 - SFF - mini ITX
System cabinet
Small form factor
I/O Connectors
2 x USB 2.0 , 2 x audio
Supported Motherboards
Mini-ITX
Power supply 200 Watt (FlexATX)
20 cm x 30.6 cm x 7.6 cm
Small form factor
Max Mainboard Size
Mini ITX
Mini-ITX
Internal Bays Qty
1
Front Accessible Bays Qty
1
Cooling System
60 x 60 x 10 mm fan mount x 1
Expansion Bays
1 (total) / 1 (free) x front accessible - 5.25" Slim Line , 1 (total) / 1 (free) x internal - 2.5"
Power supply
Specification Compliance
FlexATX
Power Provided
200 Watt
20 cm
30.6 cm
7.6 cm
