Akasa Connect 9 multi-card reader with USB hub
Quicklinx: 5CN5WS00 Mfr#: AK-HC-02BK
CONNECT9 is a complete solution for mobile computer connectivity. Six-slot card reader accommodates all popular memory cards and three-port USB hub enables connection of up to three devices. The compact and stylish design makes it a digital lifestyle smart solution. Memory slots are active allowing simultaneous or cross transfer data from different media cards. With dedicated ports for Micro SD and MM2, no memory card adapters are required. Full support for high capacity cards such as SDHC is built in.
CONNECT9 is powered directly from a USB port and doesn't require software installation. Hi-speed USB2.0 compatibility provides maximum operating speed of 480Mb/s for the card reader and three additional low power devices.
Akasa CONNECT9 - card reader
Card reader - external
Supported Memory Cards
CompactFlash Card type I, CompactFlash Card type II, Memory Stick, Memory Stick PRO, MultiMediaCard, SD Memory Card, Memory Stick PRO Duo, CompactFlash Card, TransFlash, MultiMediaCardmobile, microSD, SDHC Memory Card, Memory Stick Micro (M2), microSDHC, xD-Picture Card Type H, xD-Picture Card Type M
Built-in USB hub
Built-in USB hub
9.4 cm
5.3 cm
1.8 cm
Memory Card
(max)
Additional Ports
3 - USB 2.0 - 4 pin USB Type A
Required Ports
1 x mini-USB Type B
Apple MacOS 9.x, Apple MacOS X, Microsoft Windows Vista / 2000 / XP
