Connect 4SX Four port USB 3.0 Hub: USB 3.0 SuperSpeed connectivity.
USB bus powered supporting 1 TB external hard drive and 3 USB flash drives simultaneously.
- Four port USB 3.0 hub
- Plug and play
- USB bus powered supporting 1 TB external hard drive and 3 USB flash drives simultaneously
- USB 3.0 port backward compatible with USB 2.0
- Application 4 ports USB 3.0 HUB
- Standards USB 3.0 (USB 2.0 backwards compatible)
- Power Mode USB powered
- USB Ports Type A female USB 3.0 ports (downstream) * 4
- Connector USB 3.0 type A
- Data Transfer Rate Up to 5Gb/s - USB 3.0 / Up to 480 Mbit/s - USB 2.0
- Product Code AK-HB-08BK
- Akasa Connect4SX - hub - 4 ports
- Hub - 4 ports
- Subtype
- USB
- Ports
- 4 x SuperSpeed USB 3.0
- USB powered
- USB 2.0, USB 3.0
- Hub - 4 ports
- Enclosure Type
- Desktop
- Subtype
- USB
- Ports
- USB powered
- USB 2.0, USB 3.0
- 5 x USB 3.0 Type A
- Cables Included
- 1 x SuperSpeed USB cable
- Plug and Play
