AK-210 Cool Blue chipset cooler. Keep your chipset cool in style. The lo-noise fan has 3 Hi-bright blue LED's and sits on a blue heatsink. The cooler is easily installed using the thermally conductive adhesive transfer tape.
- Lo-noise Chipset cooler.
- 3 Hi-bright blue LED fan on Blue heatsink.
- Lo-profile, only 24mm high.
- Thermal conductive adhesive transfer tap (DG765) pre-applied.
- Tool free and easy installation.
- Akasa Cool Blue AK-210 - chipset cooler
- Product Type
- Chipset cooler
- Fan Diameter
- 40 mm
- Fan Bearing
- Sleeve bearing
- Rotation Speed
- 5000 rpm
- Air Flow
- 5.2 cfm
- Noise Level
- 23 dBA
- Blue LED fan
- Product Type
- Chipset cooler
Heatsink & Fan
- Fan Diameter
- 40 mm
- Fan Bearing
- Sleeve bearing
- Rotation Speed
- 5000 rpm
- Air Flow
- 5.2 cfm
- Noise Level
- 23 dBA
- Blue LED fan
Customer reviews
Write a review for the Akasa Chipset cooler, 3 Blue LED lo-noise Thermally Cond here!
sticky pad?
Reviewed by MikeT. Review Posted 18/12/2008
To those buyers slagging of Akasa for using thermal tape - the tape they use is generally being acknowledged as the best in the industry and does a remarkable job.
After using it literally thousands of times over the last 10 or so years, I suspect you failed to clean your old chip of the previous heatsink bonding material - that would definitely have caused the slippage.
A bit of isopropy will do the job, or at a push - vodka :)
- Overall
- Ease of use
- Value for money
great
Reviewed by Lee Murphy. Review Posted 15/05/2007
well done to akasa again all my cooling kits are supplied by them and all do what they say on the box this little chipset cooler is well easy to install (But u might have probs removing the original first) has a nice big heat sink with a proper silent fan and comes in a wicked cool blue cooler to with blue leds
- Overall
- Ease of use
- Value for money
Fan AND Heatsink
Reviewed by Anonymous Review Posted 31/05/2007
My fan came with a heatsink.
- Overall
- Ease of use
- Value for money
The opinions expressed in this reviews section are those of our customers and not of BT Business Direct. Nothing contained herein amends BT Business Direct’s terms and conditions.
