Akasa AK-FN059 120mm Ultra Quiet Viper Cool Fan - 3/4 Pin
Quicklinx: 70LXWS00 Mfr#: AK-FN059
High performance 12cm fan comes with S-flow blades supplying 30% more airflow than a standard fan at the same speed. The greater performance combined with PWM automatic speed control allows the fan noise to be kept to a minimum.
The Viper fan creates more focused airflow providing blind-spot cooling, which makes it an ideal solution for a case or heatsink fan. HDB (Hydro Dynamic) bearings extend fan life and further enhance noise reduction.
Akasa AK FN059 - case fan
Case fan
Package Content
Mounting bracket
Fan Diameter
120 mm
Fan Height
25 mm
Fan Bearing
Hydrodynamic bearing
Rotation Speed
600-1900 rpm
Air Flow
83.6 cfm
Noise Level
6.9 dBA
Power Connector
4-pin fan connector
Rated Voltage
12 V
Pulse-width modulation (PWM) support
12 cm x 12 cm x 2.5 cm
Case fan
Package Content
Mounting bracket
12 cm
12 cm
2.5 cm
Heatsink & Fan
Fan Diameter
120 mm
Fan Height
25 mm
Fan Bearing
Rotation Speed
600-1900 rpm
Air Flow
83.6 cfm
Air Pressure
2.98 mm
Noise Level
6.9 dBA
Power Connector
4-pin fan connector
Rated Voltage
12 V
Rated Current
0.17 A
Mounting Kit
Included
