Akasa 5.25" InterConnect Pro USB Panel Multicard Reader
Quicklinx: 7SQ0WS00 Mfr#: AK-HC-05BKV2
Conveniently positioned at the front of your PC, this six slot media card reader accepts most available cards in a single location. Includes additional USB ports and eSATA port for extra connectivity. Easy to install.
Internal USB 3.0 19 pin motherboard connector, Internal USB2.0 motherboard header & SATA connector
  • Brushed aluminum fascia panel
  • 6-slot card reader
  • 4-port USB 2.0 HUB
  • SuperSpeed USB 3.0 connection
  • 2 x USB 3.0 ports, backwards compatible with USB 2.0
  • eSATA port
  • For 5.25" PC front bay
  • Application 5.25" PC bay
  • Memory Card Slot 6
  • Memory card types Compact Flash (CF I, CF II, Ultra, Extreme, I-Pro, Ultimate, MD) / Memory Stick (MS Pro, MS Pro Duo, Magic Gate, Extreme, Ultra) / Secure Digital (SDXC, SDHC, SD, Ultra, Extreme, Elite Pro, High Speed, MMC, MMC Mobile) / 64GByte for SDXC - 32GByte for SDHC / Extreme Digital (X card, Type H, Type M) / M2 (Memory Stick Micro M2) / microSD (microSDHC, High Capacity)
  • Rear connectors Internal USB 2.0 motherboard connector, 2 x USB 3.0 type A male ports, eSATA port
  • Data Transfer Rate 5Gb/s (USB 3.0) and 480Mb/s (USB 2.0)
  • LED indicator Power On, Card In & Data Transfer
  • USB Ports 4-port USB 2.0 HUB / 2 x USB 3.0 ports, backwards compatible with USB 2.0
  • eSATA Ports 1
  • Supported OS Windows 2000 / XP / VISTA / 7
  • Plug & Play Supported
Akasa InterConnect Pro - card reader - USB 2.0
Card reader - external
Supported Memory Cards
CompactFlash Card type I, CompactFlash Card type II, Memory Stick, Memory Stick PRO, SD Memory Card, xD-Picture Card, Memory Stick PRO Duo, CompactFlash Card, RS-MMC, microSD, SDHC Memory Card, Memory Stick Micro (M2), microSDHC, xD-Picture Card Type H, xD-Picture Card Type M, SDXC Memory Card
Host Interface
USB 2.0
Required Bay
5.25" internal
Built-in USB hub, power indicator
Host Interface
USB 2.0
Required Bay
5.25" internal
Memory Card
(max)
Additional Ports
1 x USB 2.0 , 2 x USB 3.0 , 3 x eSATA
Required Ports
1 x 4 pin USB Type A , 2 x 9 pin USB Type A , 1 x 7 pin Serial ATA
Microsoft Windows 2000/XP/Vista/7
Plug and Play
