Unleash the power of high speed memory card
- SuperSpeed USB 3.0 card reader
- SuperSpeed USB 3.0 port
- USB 2.0 HUB
- USB 3.0 card reader unleash the power of high speed memory card
- Four card-slots are active at the same time, allowing cross format data transfer
- USB 2.0 HUB with independent power design
- USB 3.0 port backwards compatible with USB 2.0
Spec
- Application 3.5" PC bay
- Memory card slots 5
- Memory card types Compact Flash (CF I, CF II, Ultra, Extreme, I-Pro, Ultimate, MD) / Memory Stick (MS Pro, MS Pro Duo, Magic Gate, Extreme, Ultra) / Secure Digital (SDXC, SDHC, SD, Ultra, Extreme, Elite Pro, High Speed, MMC, MMC Mobile) / 64GByte for SDXC - 32GByte for SDHC / M2 (Memory Stick Micro M2) / microSD (microSDHC, High Capacity)
- Interface Internal USB 2.0 motherboard connector, internal USB 3.0 motherboard connector, USB 3.0 A male connector, SATA connector, 4-Pin PSU molex connector
- Data transfer rate 5Gb/s (USB 3.0) and 480Mb/s (USB 2.0)
- LED indication Power On, Card In & Data Transfer
- Power mode USB and 4-Pin PSU molex
- Supported OS Windows 2000 / XP / VISTA / 7
- Plug & Play Supported
- Product code AK-ICR-17
Internal USB 2.0 motherboard connector, internal USB 3.0 19 pins motherboard connector, USB 3.0 A male connector, SATA connector, 4-Pin PSU molex connector
- Akasa AK-ICR-17 - card reader - USB 2.0
- Product Type
- Card reader - internal
- Supported Memory Cards
- CompactFlash Card type I, CompactFlash Card type II, Memory Stick, Memory Stick PRO, SD Memory Card, Memory Stick PRO Duo, CompactFlash Card, microSD, SDHC Memory Card, Memory Stick Micro (M2), microSDHC, SDXC Memory Card
- Host Interface
- USB 2.0
- Required Bay
- 3.5" internal
- Built-in USB hub, status indicator
- Product Type
- Host Interface
- USB 2.0
- Required Bay
- 3.5" internal
Memory Card
- Capacity
- (max)
- Required Ports
- 1 x 4 pin USB Type A , 1 x 7 pin Serial ATA , 2 x 9 pin USB Type A
- OS Required
- Microsoft Windows 2000/XP/Vista/7
- Plug and Play
