Akasa 3.5" Internal 6-Slot Multicard Reader With Bluetooth
Quicklinx: 7NHXWS00 Mfr#: AK-ICR-11
Conveniently positioned at the front of your PC, this six slot media card reader accepts most available cards including SDXC. Includes Bluetooth for extra connectivity. Easy to install with a choice of two fascia plates, black or classic-white.
  • Accepts all popular memory cards
  • Bluetooth enabled
  • Supports SDXC cards
  • Fits 3.5" PC bay
Specification
  • Application: 3.5" PC bay
  • Memory card slots: 6
  • Memory card types: Compact Flash (CF I, CF II, Ultra, Extreme, I-Pro, Ultimate, MD) / Memory Stick (MS Pro, MS Pro Duo, Magic Gate, Extreme, Ultra) / Secure Digital (SDXC, SDHC, SD, Ultra, Extreme, Elite Pro, High Speed, MMC, MMC Mobile) / 64GByte for SDXC - 32GByte for SDHC Extreme Digital (X card, Type H, Type M) / M2 (Memory Stick Micro M2) / microSD (microSDHC, High Capacity)
  • Interface: USB 2.0 (1.1/1.0 compatible)
  • Data transfer rate: up to 480 Mb/s
  • Bluetooth: up to 10 meter operation range
  • LED indication: Power On, Card In & Data Transfer
  • Power mode: USB powered
  • PC connection: Internal USB motherboard header
  • Supported OS: Windows 2000 / XP / VISTA / 7
  • Plug & Play: Supported
Akasa Internal Card Reader AK-ICR-11 - card reader - USB 2.0
Card reader - internal
Supported Memory Cards
Memory Stick, SD Memory Card, CompactFlash Card, SDHC Memory Card, Memory Stick Micro (M2), microSDHC, SDXC Memory Card
Host Interface
USB 2.0
Required Bay
3.5" internal
Built-in Bluetooth module
Host Interface
USB 2.0
Required Bay
3.5" internal
Memory Card
(max)
Microsoft Windows 2000/XP/Vista/7
2 front panels
Plug and Play
