- SuperSpeed USB 3.0 port
- Five slot memory card reader
- USB 2.0 HUB
- Three card-slots are active at the same time, allowing cross format data transfer
- USB 2.0 HUB with independent power design
- USB 3.0 port backwards compatible with USB 2.0
Spec
- Application 3.5" PC bay
- Memory card slots 5
- Memory card types: Compact Flash (CF I, CF II, Ultra, Extreme, I-Pro, Ultimate, MD) / Memory Stick (MS Pro, MS Pro Duo, Magic Gate, Extreme, Ultra) / Secure Digital (SDXC, SDHC, SD, Ultra, Extreme, Elite Pro, High Speed, MMC, MMC Mobile / 64GByte for SDXC - 32GByte for SDHC / M2 (Memory Stick Micro M2) / microSD (microSDHC, High Capacity)
- Rear connector Internal USB 2.0 motherboard connector, internal USB 3.0 motherboard connector, SATA connector, 4-Pin PSU molex connector. Data transfer rate 5Gb/s (USB 3.0) and 480Mb/s (USB 2.0)
- LED indication Power On, Card In & Data Transfer
- Power mode USB and 4-Pin PSU molex
- Supported OS Windows 2000 / XP / VISTA / 7
- Plug & Play Supported
- Product code AK-ICR-16
Internal USB 2.0 motherboard connector, internal USB 3.0 19pins motherboard connector, SATA connector, 4-Pin PSU molex connector
- Akasa AK-ICR-16 - card reader - USB 2.0
- Product Type
- Card reader - internal
- Supported Memory Cards
- CompactFlash Card type I, CompactFlash Card type II, Memory Stick, Memory Stick PRO, MultiMediaCard, SD Memory Card, Memory Stick PRO Duo, CompactFlash Card, MultiMediaCardmobile, microSD, SDHC Memory Card, Memory Stick Micro (M2), microSDHC, SDXC Memory Card
- Host Interface
- USB 2.0
- Required Bay
- 3.5" internal
- Built-in USB hub, status indicator
- Product Type
- Host Interface
- USB 2.0
- Required Bay
- 3.5" internal
Memory Card
- Capacity
- (max)
- Required Ports
- 1 x 4 pin USB Type A , 1 x 9 pin USB Type A , 1 x 7 pin external Serial ATA
- OS Required
- Microsoft Windows 2000/XP/Vista/7
- Plug and Play
