Akasa 140mm Apache Black Edition PWM Fan, HDB Bearing
Quicklinx: 7PPXWS00 Mfr#: AK-FN062
14cm APACHE Black: S-FLOW fan blade design delivers 30% higher airflow.
Super silent 14cm fan with S-FLOW blades supplying 30% more airflow than a standard fan at the same speed. The greater performance combined with PWM automatic speed control allows the fan noise to be kept to a minimum.
The Apache fan creates more focused airflow providing blind-spot cooling, which makes it an ideal solution for a case or heatsink fan. HDB (Hydro Dynamic) bearings extend fan life and further enhance noise reduction.It's powerful and quiet!
  • Super silent APACHE BLACK 14cm fan
  • S-FLOW fan blade design delivers 30% higher airflow
  • Super silent with PWM speed control
  • Hydro Dynamic Bearing extends fan life
  • Application PC case or heatsink fan
  • Dimension 140 X 140 X 25mm
  • Fan speed 600 -1300 RPM
  • Max airflow 89.55 CFM
  • Max static air pressure 2.76 mm H2O
  • Noise level 12.5 -22.19 dB(A)
  • Voltage rating 12V DC
  • Bearing HDB (Hydro Dynamic Bearing)
  • Fan life expectancy 50,000 hours
  • Connector 4pin PWM
Akasa APACHE AK-FN062 - case fan
Case fan
Fan Diameter
140 mm
Fan Height
25 mm
Fan Bearing
Hydrodynamic bearing
Rotation Speed
600-1300 rpm
Air Flow
89.6 cfm
Noise Level
12.5 - 22.2 dBA
Power Connector
4-pin fan connector
Rated Voltage
12 V
Pulse-width modulation (PWM) support
14 cm x 14 cm x 2.5 cm
Anti-vibration
Case fan
14 cm
14 cm
2.5 cm
Heatsink & Fan
Fan Diameter
140 mm
Fan Height
25 mm
Fan Bearing
Rotation Speed
600-1300 rpm
Air Flow
89.6 cfm
Air Pressure
2.76 mm
Noise Level
12.5 - 22.2 dBA
Power Connector
4-pin fan connector
Rated Voltage
12 V
Mounting Kit
Included
Anti-vibration
