AG Neovo X19AV 1280 x 1024 DVI-D VGA LCD Monitor
Quicklinx: 64J7WS00 Mfr#: X-19AV
Marketing description is not available.
  • Wide viewing angles
    With horizontal and vertical viewing angles of 170 degrees, the Neovo X19AV offers a comfortable viewing experience from a variety of positions, making it suitable for both individual and collaborative work environments.
  • High color fidelity
    Supporting 16.7 million colors with a 24-bit color depth, this monitor delivers vibrant and accurate color representation, ensuring that images and videos appear with lifelike quality.
  • Versatile connectivity
    Equipped with DVI-D, VGA, S-video, and composite video inputs, the Neovo X19AV provides flexible connectivity options, allowing it to easily integrate into a variety of setups, from simple desktops to complex multimedia systems.
  • Energy efficient
    Being ENERGY STAR certified, the Neovo X19AV not only meets strict energy efficiency guidelines but also ensures reduced operational costs and a smaller carbon footprint, making it an eco-friendly choice for conscious consumers.
Neovo X19AV - LCD monitor - 19"
LCD monitor - 19"
Native Resolution
1280 x 1024
Pixel Pitch
0.294 mm
Brightness
300 cd/m²
Contrast Ratio
700:1
Response Time
25 ms
Colour Support
16.7 million colours
Input Connectors
DVI-D, VGA, S-Video, composite video
Screen Coating
Anti-glare, hard coating, NeoV Crystal Optic Filter
Voltage
44.4 cm x 17.5 cm x 41.9 cm
7.3 kg
Environmental Standards
ENERGY STAR Qualified
FCC Class B certified, UL, TUV, VCCI, BSMI, cUL, DDC-1, DDC-2B, ISO 13406-2, NORDIC, NUTEK, VESA DPMS, VESA FPMPMI
3-year warranty
Display Type
LCD monitor / TFT active matrix
Diagonal Size
19"
Native Resolution
1280 x 1024
Pixel Pitch
0.294 mm
Brightness
300 cd/m²
Contrast Ratio
700:1
Colour Support
Response Time
25 ms
Vertical Refresh Rate
75 Hz
Horizontal Refresh Rate
80 kHz
Video Bandwidth
135 MHz
Horizontal Viewing Angle
170
Vertical Viewing Angle
170
Screen Coating
Colour Temperature
9300K, 6500K, 5500K
Controls & Adjustments
Brightness, contrast, H/V position, sharpness, input select, colour temperature, phase, clock
OSD Languages
English, German, French, Italian, Russian, Spanish
7.3 kg
1 x VGA - 15 pin HD D-Sub (HD-15) , 1 x DVI-D - 24+5 pin combined DVI , 1 x S-video input - 4 pin mini-DIN , 1 x composite video input - RCA
Mechanical
VESA Mounting Interface
100 x 100 mm
Security lock slot (cable lock sold separately), wall mountable
1 x VGA cable , 1 x DVI cable , 1 x S-Video cable , 1 x video cable
Backlight Life
50,000 hours
Power Supply
External
Input Voltage
Sustainability Information
ENERGY STAR Certified
Limited warranty - 3 years
