Adobe InDesign CS6 software is a versatile desktop publishing application that gives you pixel-perfect control over design and typography. Create elegant and engaging pages for print, tablets, and other screens. Use adaptive design tools to easily repurpose layouts to look great on a variety of pages sizes, orientations, or devices.
Liquid layout
Apply liquid page rules to automatically adapt content when you create an alternate layout with a different size or orientation in InDesign. -
Alternate layout
Efficiently create and design multiple versions of a layout for different devices and print needs, all within a single InDesign file. -
Linked content
Link content within or across InDesign documents so that changes (including interactivity) made to the parent text or object are applied to all linked children objects. -
Content collector tools
Grab text and objects from an existing layout using the content collector. In layout, use the content placer to add items in the order you want them to appear. -
PDF forms within InDesign
Create form fields directly within InDesign before you export to PDF. You can also assign the tab order in InDesign using the Articles panel. -
Pages panel enhancements
Display alternate layouts in the Pages panel to organize content efficiently. -
Split window
View two side-by-side layouts within the same document to compare the look and feel of the layouts and help ensure consistency. -
Recently used fonts
Access fonts you use frequently. Recently used fonts appear at the top of the font list. -
Grayscale preview
Preview your layouts in grayscale to see how they will look on a black-and-white device or when printed in black and white. -
Grayscale PDF export
Export PDF files in grayscale directly from the Print dialog box.
- Adobe InDesign CS6 - box pack (upgrade) - 1 user
- Product Type
- Box pack (upgrade)
- Category
- Creativity application - desktop publishing
- Licence Qty
- 1 user
- Platform
- MacOS
- Language
- EU English
- Distribution Media
- DVD-ROM
- Category
- Product Type
- Platform
- MacOS
- DVD-ROM
- Language
- EU English
Licencing
- Licence Qty
- 1 user
- Supported OS
- Apple MacOS X Lion 10.7, Apple MacOS X 10.6.8
- Hardware Requirements
- RAM 1 GB - HD 2.6 GB
- Additional Requirements
- DVD-ROM, Internet connection, 16-bit graphics card, 1024 x 768 monitor resolution, Adobe Flash Player 10
