Adobe Premiere Pro CS6 software is the industry-leading cross-platform video editing software. Edit low-resolution to 5K and higher resolution footage comes with greater speed and precision without transcoding. Get stunning 64-bit performance, highly intuitive workflows, enabled for timesaving Adobe integration, and project exchange with Final Cut Pro and Avid NLE software. Stabilize footage with the innovative Warp Stabilizer, easily create and edit multicam sequences, adjust effects in real time during playback, and quickly encode finished video for virtually any screen.
Sleek, highly intuitive, and customizable user interface
View more of your media with redesigned monitor panels, customizable button bars, and full-screen mode option. Work more easily with sound with the new audio track design, improved meters, and a revamped Mixer panel. -
Fluid editing workflow
Take advantage of the most requested editing enhancements, including over 50 enhancements to smooth the transition for those switching from another NLE. Mix audio with ease and use convenient, customizable keyboard shortcuts to handle a wide range of common tasks. -
Dynamic timeline trimming
Finesse your editing with precision using powerful trimming tools. Trim clips your way - directly in the timeline via keyboard entry or dynamically in the Program Monitor using JKL shortcuts. -
Warp stabilizer effect
Easily stabilize a bumpy camera move or lock a shot automatically with the same powerful technology as in After Effects software. The Warp Stabilizer removes jitter and compensates for rolling shutter artifacts and other motion-related irregularities. -
Powerful multicam editing
Quickly and easily edit multicam footage from as many cameras as you have on the shoot. View each track's audio waveform, sync via timecode, switch between tracks in real time, and adjust color across multiple shots. -
Adjustment layers
Apply effects that span multiple clips. Create adjustment layers, similar to those in Adobe Photoshop and After Effects software, to apply effects to clips on tracks below them. Easily create masks to adjust a selected area of a shot. -
Fast project panel workflows
View, sort, and arrange media easily with the resizable clip thumbnails in the revamped visual Project panel. Quickly assemble rough cuts by scrubbing clips and setting in and out points directly in the Project panel, without first having to load clips into the Source Monitor. -
Enhanced Adobe mercury playback engine
Work dramatically faster with sweeping performance and stability enhancements to the natively 64 bit, multicore-CPU optimized, and GPU-accelerated engine. New support for OpenCL on certain MacBook Pro computers brings GPU-accelerated workflows to Mac computer users, while support for NVIDIA Maximus dual-GPU systems delivers even more extreme performance. -
Broad native format support
Save time and maximize quality by working natively with almost every video format, without having to transcode or rewrap footage. Take advantage of new support for ARRI ALEXA, RED EPIC, RED SCARLET-X, and Canon Cinema EOS C300 cameras. -
Flexible audio tracks
Freely combine and pan mono and stereo clips. Adaptive audio track types and an easier way to create a multi-channel master deliver greater audio flexibility. -
More powerful color workflows
Easily manage the color in your projects with a more intuitive Three-Way Color Corrector for precise primary and secondary color correction. -
Adobe mercury transmit
Experience better performance than ever before with third-party I/O hardware devices, including full-screen playback on external monitors, through Mercury Transmit, which gives I/O hardware partners direct access to the Adobe Mercury Playback Engine. -
Rolling shutter repair effect
Easily repair media with rolling shutter artifacts such as wobble and skew. Based on technology in the Warp Stabilizer, this powerful effect can be applied without stabilization and offers enhanced controls. -
Adobe Prelude CS6 software integration
Use Adobe Prelude software to efficiently log footage, create rough cuts to bring into Adobe Premiere Pro software, and add comments and markers that are associated with the media, simplifying organization and helping to make your final video more discoverable online. -
Uninterrupted playback
Stay in the creative editing zone. Make changes on the fly without playback stopping until you ask it to. Edit, trim, and apply filters; adjust their parameters and add effects in real-time, all during looping playback. -
Faster Adobe workflows
Effortlessly move assets among Adobe Premiere Pro, After Effects, Photoshop Extended, Encore, Illustrator, and Adobe Audition software. Seamlessly open an After Effects composition in Adobe Premiere Pro software without intermediate rendering, thanks to the faster-than-ever Adobe Dynamic Link. -
Integrated with Adobe SpeedGrade CS6 software
Easily export your Adobe Premiere Pro sequences into Adobe SpeedGrade CS6 software for a complete finishing solution. In Adobe SpeedGrade software, handle grading tasks like matching shots and creating consistent nuanced color to visually enhance your projects. -
Improved third-party tool interoperability
Easily exchange projects with Final Cut Pro and Avid software, and other third-party tools and applications, thanks to improved support for industry-standard XML, AAF, and OMF interchange formats. -
Fast, sure output to virtually any device or format
Quickly and easily output your work for nearly any screen with Adobe Media Encoder. Set, customize, and organize your favorite presets in the Preset Browser for fast export and batch encoding in the background. -
DVD, Blu-ray Disc, and web DVD authoring
Efficiently create DVDs, Blu-ray discs, and web DVDs, all from a single project, using 64-bit Encore CS6 software. Open sequences without rendering and use flowcharts to define and view the navigation of your project.
- Adobe Premiere Pro CS6 - box pack - 1 user
- Product Type
- Box pack
- Category
- Creativity application - video editing & production
- Licence Qty
- 1 user
- Platform
- MacOS - 64-bit
- Language
- EU English
- Distribution Media
- DVD-ROM
- Category
- Product Type
- Box pack
- Platform
- MacOS - 64-bit
- DVD-ROM
- Language
- EU English
Licencing
- Licence Qty
- 1 user
- Supported OS
- Apple MacOS X Lion 10.7, Apple MacOS X 10.6.8
- Hardware Requirements
- RAM 4 GB - HD 4 GB
- Additional Requirements
- DVD-ROM, Internet connection, 1280 x 900 monitor resolution, 7200 RPM or faster hard drive, OpenGL 2.0 compatible graphics card, QuickTime 7.6.6 or later
