Adobe Illustrator CS6 V16 Mac
Quicklinx: 83QTWS00 Mfr#: 65165612
Adobe Illustrator CS6 software is powered by the Adobe Mercury Performance System so you can work with speed and stability on large, complex files. A modern, updated interface streamlines daily tasks. Advanced creative tools enable you to capture your vision better than ever.
Adobe Illustrator CS6 software is the industry's premier vector-drawing environment for creating graphics that scale across media. Capture your vision with shapes, color, effects, and typography while working efficiently and moving easily among Adobe creative applications. Experiment freely with perspective, image tracing, transparent gradients, patterns, brushes, and strokes - all driven by the Mercury Performance System so you can make fast work of your most complex designs.
  • Sophisticated vector drawing tools
    Create distinctive designs with precise shape-building tools, fluid and painterly brushes, and advanced path controls.
  • Integration with other Adobe solutions
    Move projects smoothly from design to print or digital output, thanks to tight integration with industry-leading Adobe software, such as Adobe Photoshop, InDesign, After Effects, Acrobat, and more.
  • Mercury performance system
    Work with precision, speed, and rock-solid stability on large, complex files due to native 64-bit support on Mac OS and Windows with RAM and overall performance optimization.
  • Multiple artboards
    Organize and view up to 100 artboards of varying sizes overlapping or on a grid. Quickly add, delete, reorder, and name. Save, export, and print independently or together.
  • Gradients and transparency
    Interact with gradients directly on your object, defining the dimension of elliptical gradients, editing colors, and adjusting opacity. Even create gradients on strokes and meshes.
  • Crisp graphics and text for web and mobile
    Create and align vector objects precisely on the file's pixel grid for clean, sharp raster graphics. Use text anti-aliasing options for individual text frames.
  • Image trace
    Confidently convert raster images to editable vectors with a powerful tracing engine. Get clean lines, accurate fitting, and reliable color results using simple, intuitive controls.
  • Perspective drawing
    Use perspective grids to draw shapes and scenes in accurate 1-, 2-, or 3-point linear perspective, creating the look of realistic depth and distance.
  • Pattern creation
    Easily create seamlessly tiled vector patterns. Experiment freely with different types of repeating patterns that can be edited at any time for maximum design flexibility.
  • In-panel appearance editing
    Edit object characteristics directly in the Appearance panel, eliminating the need to open fill, stroke, or effects panels.
  • Industry-standard graphic file formats
    Work with almost any type of graphic file - including PDF, EPS, FXG, Photoshop (PSD), TIFF, GIF, JPEG, SWF, SVG, DWG, DXF, and more.
  • Adobe PDF file creation tools
    Create more secure, multipage, graphic-rich PDF files with Illustrator layers retained. Share files confidently with service providers knowing that Illustrator supports PDF/X standards.
Adobe Illustrator CS6 - box pack - 1 user
Box pack
Category
Creativity application - graphics & image editing
Licence Qty
1 user
Platform
MacOS
Language
EU English
Distribution Media
DVD-ROM
Category
Box pack
Platform
MacOS
Distribution Media
DVD-ROM
Language
EU English
Licencing
Licence Qty
1 user
Supported OS
Apple MacOS X Lion 10.7, Apple MacOS X 10.6.8
Hardware Requirements
RAM 2 GB - HD 2 GB
Additional Requirements
DVD-ROM, Internet connection, 16-bit graphics card, 1024 x 768 monitor resolution
