Adobe FrameMaker Server 8.0 Upgrade Unix
Quicklinx: 6D56WS00 Mfr#: 37980040
Adobe FrameMaker Server software enables you to integrate the powerful print and Adobe PDF publishing features of FrameMaker with server-based applications. FrameMaker Server lets you efficiently produce personalized, accurate, high-quality print and Adobe PDF output of data-driven content. Composed documents may be delivered as Adobe PDF files to a Web browser or file server, or as Adobe PostScript language files streamed directly to a printer.
  • Automated publishing delivered remotely
    Access the powerful, automated, multichannel, multiscreen publishing capabilities of Adobe FrameMaker Publishing Server 12 as a web service. Work more flexibly by scheduling publishing tasks anytime, anywhere using your web browser. You can also integrate and schedule the FrameMaker publishing service from your content management system.
  • Comprehensive multiuser support
    Allow multiple users to access publishing services and run tasks remotely, at the same time, using their web browser. On logging in, users are able to see their own publishing tasks, output status, next-run date and time, and logs generated; as well as their templates and presets, and shared templates.
  • Increase enterprise productivity
    Schedule publishing tasks to be automatically executed, manage with a comprehensive easy-to-use dashboard, and eliminate repetitive processes with publishing task templates and reusable publishing presets. Leverage scripting support, shared APIs, and integration with Windows Task Scheduler to work more efficiently.
  • Comprehensive, user-friendly publishing dashboard
    Increase enterprise productivity by managing publishing centrally. Create new publishing tasks by choosing the source file and types of output, and specifying settings for each output required. Run your tasks instantly or schedule them for later. Easily view logs, outputs, and published status, and sign up for notifications.
  • Creation and reuse of publishing task templates
    Work productively with shareable, editable publishing task templates, in which you specify outputs and their associated settings, prepublishing and post-publishing tasks, notifications, and output location. Use template to publish with different source files, and create tasks that will inherit the template’s settings.
  • Reusable presets for publishing
    Save time and effort by defining publishing presets. Use these presets with different source files to avoid having to specify settings repeatedly. Share your presets with other users across the organization, and standardize the appearance of enterprise content.
  • Scripting support for automation
    Perform custom processing on the input files in prepublication state. Create scripts with Adobe ExtendScript Toolkit to automate publication tasks, including prepublication tasks such as applying conditional text for single-sourced publication tasks.
  • Publishing DITA maps to books
    Easily publish your DITA content to professional-looking output. Generate nested books and books with flat components. Create attractive book content from DITA maps by automatically generating titles and tables of contents, applying number properties, and page rounding. Easily publish directly to PDF from the DITA map or through the book.
  • Shareable publishing task configuration
    Reuse settings to set up similar publishing tasks. For example, if you created a task to output PDF, multiscreen HTML5, WebHelp, and eBook (EPUB 3, KF8) formats from a set of source documents, you can edit this task to create a task for other source types.
  • Post-publish commands
    Automatically run post-publish system commands or batch files. Use post-publish commands to automatically rename, move, or archive output files, especially when running regular builds, so that subsequent builds do not overwrite earlier output files.
  • Extensive logging
    Take advantage of extensive logging for all processes in publication tasks to comprehensively report all tasks executed by FrameMaker Publishing Server. You can customize the level of logging and the parameters to be logged, and view logs for recently completed runs of the same task.
  • Publish to multiple screens and formats
    Generate responsive HTML5 output for a wide range of screens. Or differentiate content for various devices with multiscreen HTML5 publishing. Deliver content to mobile devices, tablets, and eBook readers in EPUB 3, KF8, and MOBI formats. Preview and optimize content for a better user experience.
  • Multichannel, multiscreen HTML5 publishing
    Usher in the future of publishing technical communication by delivering rich, interactive content virtually anywhere. Publish frameless, cross-browser, cross-platform, multiscreen HTML5 output to a wide range of channels (such as mobile, web, desktops, and print) and screens (including tablets and smartphones).
  • HTML5 output with single responsive layout
    Make your legacy projects mobile-friendly with very little effort. Generate a single set of HTML5 files, with consistent look-and-feel, for multiple devices. Provide an optimized app-like experience across mobile devices by simply selecting or customizing a responsive HTML5 layout from the gallery.
  • Automatic, screen-based content optimization
    Allow users to optimize each screen profile based on the size of the output screen by converting auto-size or text-only pop-ups to hyperlinks, changing absolute image and table sizes to relative sizes. Enable the pinch-to-zoom feature, and replace SWF content with Adobe Captivate HTML5 files on iOS devices.
  • Device-based screen profiles
    Leverage the scalable, extensible multiscreen HTML5 format to make output look its best on a range of devices. Create new profiles, specify a range of dimensions or resolutions for each of them, provide screen frame images for better previewing of output screens, and specify the browser agents to use to access the content.
  • Broad range of input formats
    Work with XML, DITA, SGML, Maker Interchange Format (MIF), native Adobe FrameMaker, and Office Filter files . Seamlessly import JPEG, GIF, PDF, CGM, and SWF files and more.
  • Preview output
    See how your documentation will appear on a wide variety of devices, even as you develop it. Click just once on the toolbar to get a facsimile of the output rendered across different types of browsers and screens such as smartphones, tablets, and desktops.
Adobe FrameMaker Server (v. 8) - box pack (upgrade) - 1 server
Box pack (upgrade)
Category
Creativity application - desktop publishing
Version
8
Licence Qty
1 server
Platform
Solaris
Language
International English
Distribution Media
CD-ROM
Category
Box pack (upgrade)
Version
8
Platform
Solaris
Distribution Media
CD-ROM
Language
Licencing
Licence Qty
1 server
Supported OS
SunSoft Solaris 8, SunSoft Solaris 9, SunSoft Solaris 10
Hardware Requirements
SunSoft Solaris 8 - RAM 512 MB - HD 1280 MB , SunSoft Solaris 9 - RAM 512 MB - HD 1280 MB , SunSoft Solaris 10 - RAM 512 MB - HD 1280 MB
Additional Requirements
CD-ROM, X Window System X11R6
