Adobe FLASH PRO CS6
Adobe FLASH PRO CS6
Quicklinx: 83QQWS00 Mfr#: 65173821
Adobe Flash Professional CS6 software is a powerful authoring tool for creating animation and multimedia content. Leverage extensive integration with Adobe Photoshop, Illustrator, and After Effects software. With pixel-precise drawing tools, professional typography, efficient coding features, high-quality video, and sprite sheet generation, you can deliver immersive interactive experiences that present consistently to audiences practically anywhere.
  • Powerful animation tools
    Create and edit motion tweens using the timeline and motion editor, and use inverse kinematics to create natural motion for character animation.
  • Advanced drawing tools
    Design artwork more precisely and efficiently with smart shapes and powerful design tools.
  • ActionScript editor
    Streamline development with the built-in ActionScript editor that features custom class code hinting and code completion. Efficiently reference your own or external code libraries.
  • Efficient mobile development workflows
    Manage FLA project files that target multiple devices. Share code and assets across documents and device targets to efficiently create, test, package, and deploy content for a wide range of screens and devices.
  • XML-based FLA source files
    Collaborate on projects more easily with an XML-based implementation of the FLA file format. Uncompressed projects act like folders, allowing you to quickly manage and modify assets.
  • Sprite sheet generation
    Export symbols and animation sequences to quickly generate sprite sheets that help improve the gaming experience, workflow, and performance.
  • Code snippets panel
    Help speed up project completion by using convenient prewritten code snippets for common actions, animation, multitouch gestures, and more. Also discover an easier way to learn how to program in ActionScript.
  • Advanced text engine
    Get global bidirectional language support and advanced print-quality typography APIs via the text layout framework. Maintain layout with greater fidelity when importing content from other Adobe applications.
  • Prepackaged Adobe AIR application creation
    Create and deliver applications with a prepackaged Adobe AIR captive runtime. Streamline application testing and enable end users to run your content without additional downloads.
  • Platform- and device-specific access
    Use prebuilt native extensions that provide access to platform- or device-specific capabilities, such as battery level and vibration.
  • Adobe AIR mobile simulation
    Simulate common mobile application interactions like screen orientation, touch gestures, and accelerometer to help speed up testing.
  • Stage 3D targeting
    Turbocharge rendering performance by using direct mode to leverage the open source Starling Framework for hardware-accelerated 2D content.
  • Multiple AIR SDK support
    Add multiple Adobe AIR software development kits (SDKs) with a menu command that helps you create more publishing targets more easily.
Adobe Flash Professional CS6 - box pack - 1 user
Box pack
Category
Creativity application - web design / publishing
Licence Qty
1 user
Platform
MacOS
Language
EU English
Distribution Media
DVD-ROM
Category
Box pack
Platform
MacOS
Distribution Media
DVD-ROM
Language
EU English
Licencing
Licence Qty
1 user
Supported OS
Apple MacOS X 10.6, Apple MacOS X Lion 10.7
Hardware Requirements
RAM 2 GB - HD 4 GB
Additional Requirements
DVD-ROM, Internet connection, 1024 x 768 monitor resolution, Java Runtime Environment 1.6, QuickTime 7.6.6 or later
