Adobe Fireworks CS6 V12 Win
Quicklinx: 83QLWS00 Mfr#: 65157707
Adobe Fireworks CS6 software helps you create beautiful designs for websites and mobile apps in a snap, all without coding. Deliver vector and bitmap images, mockups, 3D graphics, and interactive content for popular tablets and smartphones. Optimize graphics and web content to display them consistently across devices. Jump-start your designs with templates, rich symbols, and reusable styles. Smooth the workflow between design and coding with CSS extraction, CSS sprites, and jQuery Mobile themes.
  • Easy-to-use screen-based design tools
    Quickly create, edit, and optimize your designs, web and mobile mock-ups, and more with easy-to-use vector and bitmap graphics tools.
  • Sophisticated prototyping
    Design interactive layouts for websites and mobile apps without writing code. Export multipage, clickable comps as CSS3-based layouts.
  • Industry-standard CSS support
    Extract CSS code and create sprites with the CSS Properties panel. Design complete web pages and export complete layouts with external style sheets in one step.
  • jQuery mobile theme skinning support
    Create jQuery Mobile themes from existing templates and CSS sprite images for mobile websites and applications.
  • CSS and HTML export
    Design complete web pages in a robust graphic environment, and then export standards-compliant, CSS-based layouts - with external style sheets - in one step.
  • Intelligent integration
    Import/export to Adobe Photoshop and Adobe Illustrator software. Copy and paste from Fireworks to Adobe Dreamweaver software. Work faster thanks to tight Integration with other Adobe solutions.
  • Photoshop and illustrator file import
    Import native Illustrator and Photoshop files, maintaining color matching, element fidelity, and editing capability in Fireworks.
  • Templates and styles
    Save time, boost productivity, and increase standardization with templates for mobile apps, web content, and designs. Add customized styles to your library.
  • Common library
    Mock up designs and themes with templates, symbols, and design components from the Common Library.
  • Developer productivity tools
    Save development time with batch processing. Create commands in the History panel. Create assets and quickly optimize them for multiple projects.
  • Improved performance
    Work smarter with a more responsive interface for Mac OS; four times larger file size support in 64-bit Windows operating systems; and easier access to common tasks like fill, gradient, and pattern.
  • API access
    Access the API to generate extensions. Benefit from community-driven extensions.
Adobe Fireworks CS6 - box pack - 1 user
Box pack
Category
Creativity application - graphics & image editing, web design / publishing
Licence Qty
1 user
Platform
Windows
Language
EU English
Distribution Media
DVD-ROM
Category
Box pack
Platform
Windows
Distribution Media
DVD-ROM
Language
EU English
Licencing
Licence Qty
1 user
Supported OS
Microsoft Windows 7, Microsoft Windows XP SP2 or later
Hardware Requirements
Pentium 4 RAM 1 GB - HD 1 GB , Athlon 64 RAM 1 GB - HD 1 GB
Additional Requirements
DVD-ROM, Internet connection, 1280 x 1024 monitor resolution, 16-bit graphics card
