Adobe Dreamweaver CS6 V12 Mac
Quicklinx: 83PWWS00 Mfr#: 65168511
Adobe Dreamweaver CS6 software enables you to make cutting-edge web designs and mobile apps while generating HTML5 and CSS3 code. Use the fluid grid layout system and HTML editor to design projects for smartphones, tablets, and desktop screens. Support for CSS3, jQuery Mobile, and Adobe PhoneGap Build frameworks streamline the mobile app development process. Check your designs with Live View and Multiscreen Preview. Add rich typography and CSS3 transitions to create compelling projects.
  • Fluid grid layout
    Construct complex web designs and layouts without getting buried in code. Fluid grid layouts help you design projects that present on different screen sizes for desktops and devices.
  • Improved FTP performance
    Save time uploading larger files with the reengineered, multi-threaded FTP transfer tool. Upload site files faster and more efficiently to speed up production time.
  • Business Catalyst integration
    Use the integrated Business Catalyst panel in Dreamweaver software to connect and edit sites you build with Adobe Business Catalyst. Build e-commerce sites with the hosted solution.
  • Enhanced jQuery mobile support
    Build native mobile apps for iOS and Android platforms using the updated support for jQuery mobile framework. Build apps to reach mobile audiences while streamlining your mobile development workflow.
  • Updated Adobe PhoneGap Build support
    Easily build and package native apps for Android and iOS with updated support for the Adobe PhoneGap Build framework. Create mobile apps by repurposing existing HTML code. Use PhoneGap emulators to check your designs.
  • CSS3 transitions
    Animate changes to CSS properties as transitions to bring web designs to life. Maintain greater control over web design as you finesse page elements and create captivating effects.
  • Updated live view
    Test pages before publishing using updated Live View functionality. Live view now uses the latest version of the WebKit rendering engine to provide the ultimate in HTML5 support.
  • Updated Multiscreen Preview panel
    Check the display of projects built for smartphones, tablets, and desktops with the updated Multiscreen Preview panel. This enhanced panel now enables you to check the rendering of HTML5 content.
Adobe Dreamweaver CS6 - box pack - 1 user
Box pack
Category
Creativity application - web design / publishing
Licence Qty
1 user
Platform
MacOS
Language
EU English
Distribution Media
DVD-ROM
Category
Box pack
Platform
MacOS
Distribution Media
DVD-ROM
Language
EU English
Licencing
Licence Qty
1 user
Supported OS
Apple MacOS X 10.6, Apple MacOS X Lion 10.7
Hardware Requirements
RAM 512 MB - HD 1.8 GB
Additional Requirements
DVD-ROM, Internet connection, 16-bit graphics card, 1280 x 800 monitor resolution, Java Runtime Environment 1.6, QuickTime 7.6.6 or later
