Adobe ColdFusion Standard 9 Upgrade from Standard
Quicklinx: 6D4HWS00 Mfr#: 65047427
ColdFusion Standard is the solution for delivering a powerful website or application on a single server. It features all the RAD development capabilities of ColdFusion, powerful features such as PDF and FlashPaper document generation, rich flash forms, structured business reporting, and more - all in an easy-to-manage configuration that is ideal for small to medium-sized businesses.
  • Server Monitor
    Improve usability through greater visibility into internal application performance. By providing information about the server - including requests, queries, memory usage, and errors - the Server Monitor and Multiserver Monitor allow you to troubleshoot and fine-tune applications in development and production. Set alerts and other actions to help prevent memory problems, slow pages, or other performance issues.
  • Multi-threading
    Improve application performance through more granular control of application threads. The CFTHREAD tag allows you to create, end, join together, or temporarily suspend the processing of specific ColdFusion threads.
  • Image manipulation
    Improve performance by minimizing I/O calls related to images. Leverage more than 50 CFML tags and functions for creating and manipulating images. For example, the CFIMAGE tag provides shortcuts to the most common image actions, including reading, writing, resizing, rotating, and converting images.
  • Presentations on demand
    Keep online presentations current by dynamically populating them with the latest available data. Create high-quality, on-demand presentations and eLearning courses with animation, audio, and video that are dynamically generated on the server with up-to-the-minute data and content from multiple external sources.
  • Atom and RSS feeds
    Easily create and read Atom and RSS feeds with less code. The CFFEED tag can read and create RSS and Atom feeds in commonly used formats, so you can quickly and easily create complex content syndication applications.
  • ZIP and JAR file features
    Easily access and manipulate ZIP and JAR files with less code. Use the CFZIP and CFZIPPARAM tags, so you can manipulate ZIP and JAR files for working with file archives.
  • User-based Administrator and RDS access
    Improve application security by restricting access to the ColdFusion server. Create multiple ColdFusion Administrator and Remote Development Services (RDS) accounts with individual permissions. Permissions determine which pages and functions are accessible in the ColdFusion Administrator and the Administrator API.
  • File manipulation functions
    Improve performance by breaking apart intensive I/O tasks with several file manipulation functions in CFML. For example, read and write large files in defined segments, rather than in a single operation.
  • Strong encryption libraries
    Improve the security of your applications with the RSA BSAFE Crypto-J libraries in ColdFusion, which provide FIPS 140-certified strong encryption.
  • Database interaction improvements
    Reduce required code by using stored procedures. The DBINFO tag allows you to programmatically access information about a data source, create stored procedures and queries using CFQUERYPARAM to be cached, and much more.
  • Argument collections
    Accelerate development by easily coding tags with many attributes. Specify an argumentsCollection attribute in most tags to specify the tag's attributes in a single structure.
  • Array and structure creation
    Reduce required keystrokes by creating arrays and structures implicitly in assignment statements without using the ArrayNew or StructNew functions.
  • .NET integration
    Build a hub application for all enterprise resources by leveraging .NET objects from other applications. Specify any .NET object - either local or remote - and use it in your ColdFusion application, just like any Java or other object resource.
  • Microsoft Exchange Server integration
    Build a hub application for enterprise personnel by including enterprise messaging, calendaring, a contact list, and task management. Programmatically access Exchange Server functionality within your ColdFusion application with easy-to-use tags.
Adobe ColdFusion Standard - box pack (version upgrade) - 2 processors
Box pack (version upgrade)
Category
Development tools - web applications
Licence Qty
2 processors
Upgrade from
Macromedia ColdFusion Standard v. 7 , Macromedia ColdFusion Standard v. 8
Platform
Linux, Windows, MacOS
Language
International English
Distribution Media
DVD-ROM
Category
Platform
Upgrade from
Distribution Media
DVD-ROM
Language
Licencing
Licence Qty
2 processors
