Adobe After Effects CS6 Complete Package - Windows
Quicklinx: 83PMWS00 Mfr#: 65174986
Industry-standard Adobe After Effects CS6 software helps you deliver cinematic visual effects and sophisticated motion graphics. Maximize 64-bit performance with global performance cache, which preserves previews whenever possible for a faster, more responsive workflow. Extend your creativity with the 3D camera tracker, text and shape extrusion, photorealistic light manipulation and superior masking.
  • Excellent compositing and animation tools
    Create high-impact communications by combining moving imagery, still images and graphics, text, and sound in 2D or 3D space and then animating virtually any aspect of each element.
  • Responsive 64-bit performance
    Work effectively on high-resolution projects - even at 32-bit-per-channel color in HD, 2K, and 4K compositions. See longer previews using all system RAM. Spend less time waiting and more time creating with smart disk caching.
  • Global performance cache
    Create more in less time, even in high-resolution projects. This "under the hood" makes After Effects fast and responsive by taking full advantage of the 64-bit power in your computer's hardware.
  • Unmatched integration with industry-standard Adobe applications
    Enjoy a streamlined workflow with support for importing Adobe Photoshop images that include layer and vanishing point exchange data, as well as Adobe Illustrator graphics that scale crisply to any resolution.
  • Unlimited creative options
    Manipulate moving and still images using hundreds of effects such as the warp stabilizer; combine effects to create Hollywood-caliber special effects.
  • Text and vector graphics creation and animation
    Create text and vector graphics and extrude them into 3D, and then animate these elements to create visually innovative motion graphics.
  • Comprehensive masking and keying tools
    Isolate moving foreground elements from backgrounds fast with the Roto Brush tool.
  • 3D camera tracker
    Track 3D elements with complete control over depth of field, shadows, and reflections. Automatically analyze and place 3D track points onto 2D footage in the background while you work.
  • Ray-traced, extruded text and shapes
    Extrude fully ray-traced text and shapes natively and take full advantage of reflections, environment maps, and more.
  • Variable mask feathering
    Create a separate set of splines to precisely control mask feathering. Get the exact shape you want with the proper degree of softness at any point along the mask edge, resulting in a big boost to creative flexibility.
  • Integration with Adobe Illustrator
    Instantly convert Illustrator vector art (AI and EPS format) into shape layers. Easily animate vector art in 2D or extrude to 3D.
  • Rolling shutter repair
    Remove rolling shutter artifacts such as skew and wobble without forcing stabilization, using an improved version of technology originally introduced with warp stabilizer.
Adobe After Effects CS6 - box pack - 1 user
Box pack
Category
Creativity application - video editing & production
Licence Qty
1 user
Platform
Windows - 64-bit
Language
EU English
Distribution Media
DVD-ROM
Category
Box pack
Platform
Windows - 64-bit
Distribution Media
DVD-ROM
Language
EU English
Licencing
Licence Qty
1 user
Supported OS
Microsoft Windows 7 64-bit Edition SP1
Hardware Requirements
Core 2 Duo RAM 4 GB - HD 3 GB , Phenom II RAM 4 GB - HD 3 GB
Additional Requirements
DVD-ROM, Internet connection, 1280 x 900 monitor resolution, OpenGL 2.0 compatible graphics card, QuickTime 7.6.6 or later
