Whether you're working in broadcast and film or delivering work online and to mobile devices, Adobe After Effects CS5 software enables you to create groundbreaking motion graphics and blockbuster visual effects.
Get 64-bit performance
Execute a wide range of post-production tasks with unmatched speed and efficiency. Native 64-bit operating system support, multiprocessor utilization, and OpenGL acceleration help you work faster, taking full advantage of your computer's power. Unmatched integration with other Adobe software further streamlines your workflow. -
Animate ideas
Express your creative ideas with freedom and flexibility using After Effects CS5. Employ 2D, 3D, text, and vector graphic compositing and animation tools; choose from an extensive selection of effects; and add high-quality audio. Explore a large library of creative building blocks to get you started, and take advantage of command line automation and scripting for advanced applications. -
Composite efficiently
Combine layers into new, visually rich alternate realities. Mask, key, motion track, color correct, paint, and perform a variety of visual effects magic with powerful, efficient, and precise tools. -
Deliver virtually anywhere
Deliver your final result to the widest range of formats, from mobile media to feature films, at maximum bit depth and resolution, using color management to ensure accurate results.
- Adobe After Effects CS5 - box pack - 1 user
- Product Type
- Box pack
- Category
- Creativity application - graphics & image editing, video editing & production
- Licence Qty
- 1 user
- Licence Pricing
- Academic
- Platform
- MacOS
- Language
- English
- Localisation
- European Union
- Distribution Media
- DVD-ROM
- Category
- Product Type
- Box pack
- Platform
- MacOS
- DVD-ROM
- Language
- English
- Localisation
- European Union
Licencing
- Licence Qty
- 1 user
- Licence Pricing
- Academic
- Supported OS
- Apple MacOS X 10.6, Apple MacOS X 10.5.7
- Hardware Requirements
- Intel multi-core processor RAM 2 GB - HD 4 GB
- Additional Requirements
- DVD-ROM, Internet connection, OpenGL compatible graphics card, 1280 x 900 monitor resolution, QuickTime 7.6.2
