Adaptec RAID 71605 Single
Quicklinx: 8Q4RWS00 Mfr#: 2274400-R
The Adaptec Series 7 RAID adapter family features PMC's 24-port PM8015 RAID-on-Chip (ROC), which combines a x8 PCIe Gen3 interface with 6 Gbps SAS ports to enable high-performance RAID adapters that are unmatched by any other ROC in the industry.
While the PCIe Gen3 interface doubles bandwidth to the host compared to PCIe Gen2, it requires at least 16 6 Gbps SAS/SATA ports to double the bandwidth to the storage devices.
  • New levels of performance
    Series 7 adapter performs at up to 6.6 Gbps on sequential reads and up to 2.6 Gbps on sequential writes on parity RAID 5, more than doubling the performance of competing host-based RAID adapters. With 16 direct-connected solid-state drives (SSDs), Series 7 adapter can deliver up to 450,000 IOPS - nearly 10x the performance of previous-generation RAID adapters.
  • Advanced data protection
    Adaptec RAID Code (ARC) delivers maximum reliability with RAID levels 0, 1, 1E, 5, 6, 10, 50 and 60. ARC also offers RAID Level Migration (the ability to easily migrate RAID levels), online capacity expansion (expand capacity without powering down the server), and copyback hot spare (when a failed drive has been replaced, data is automatically copied from the hot spare back to the restored drive).
  • Connectivity
    Series 7 adapter supports all types of devices including drives, tapes, autoloaders, external RAID systems. It supports migration of disk drives from standard Host Bus Adapters (HBAs) as well as onboard SATA or SAS interfaces from the motherboard.
  • Mini SAS HD connectors
    These connectors allow for greater flexibility in configuration options by supporting up to 16 native SAS/SATA ports in a low-profile MD2 form factor and up to 24 SAS/SATA ports in a full-height half-length form factor. The connectors can be combined with a wide range of Adaptec SAS HD cables, including straight connectors or Adaptec's first to market right angle connectors.
Microchip Adaptec RAID 71605 - storage controller (RAID) - SATA 6Gb/s / SAS 6Gb/s - PCIe 3.0 x8
Storage controller (RAID) - plug-in card - low profile
Bus Type
PCIe 3.0 x8
Data Transfer Rate
6 Gbit/s
Buffer Size
1024 MB
Supported Devices
Disk array (RAID)
Channel Qty
16
Max Storage Devices Qty
16
RAID Level
RAID 0, RAID 1, RAID 5, RAID 6, RAID 10, RAID 50, RAID 1E, RAID 60
SunSoft Solaris, FreeBSD, Red Hat Linux, Microsoft Windows, Debian Linux, Red Hat Fedora Core, openSUSE, Ubuntu, VMware ESX
16.7 cm x 6.4 cm
3-year warranty
Host Bus
PCIe 3.0 x8
Storage Controller
Data Transfer Rate
6 Gbit/s
Buffer Size
1024 MB
Supported Devices
Disk array (RAID)
Channel Qty
16
16
RAID Level
4 x SATA 6Gb/s / SAS 6Gb/s
Compatible Slots
1 x PCI Express 3.0 x8 - low-profile
MTBF
700,000 hours
UL, VCCI, C-Tick, cUL, FCC, RoHS, KCC
Limited warranty - 3 years
16.7 cm
6.4 cm
55 °C
