Adaptec series 6E unified serial SATA/SAS RAID controller delivers the robustness of hardware RAID and the Adaptec RAID code, enterprise class management features, and full OS support. Delivering the same 6 Gb/s performance of the series 6 controller, the series 6E is optimized for platform where a series 6 controller would not fit in from a price, form factor or host connectivity standpoint.
Series 6E controller supports SATA and SAS devices, and has been qualified with the same systems, motherboards, backplanes and drives as series 6 controller. It includes the same drivers, BIOS and storage management tools as series 6 controller and do not require additional training or qualification. Series 6E controller has also been thoroughly tested with entry-level storage devices for desktop use and the entry-level server platforms, workstations and motherboards most typically used for basic servers, performance workstations or industrial PCs.
I/O connectivity and data protection
With its entry-level price point, Adaptec series 6E can be used as a connectivity product. At the same time, the Adaptec RAID Code (ARC) delivers maximum reliability with RAID levels 0, 1, 1E, 10 and JBOD. ARC also offers RAID level migration, online capacity expansion, and copyback hot spare. -
The case for cache
The fastest way for a RAID controller to fulfill a read or write request is to serve data out of its cache. Savvy network administrators know that enabling the RAID controller cache offers significant performance benefits, such as reduced latency in I/O requests, bandwidth and queue depths that surpass software application limits, and on-the-fly parity calculations on sequential writes. -
Intelligent Power Management
Intelligent Power Management (IPM) slashes power and cooling costs by up to 70% using intelligent I/O caching combined with disk drive power savings via standby and power-off modes.
- Microchip Adaptec RAID 6805E - storage controller (RAID) - SATA 6Gb/s / SAS 6Gb/s - PCIe x4
- Storage controller (RAID) - plug-in card - low profile
- Bus Type
- PCIe x4
- Interface
- Data Transfer Rate
- 6 Gbit/s
- Buffer Size
- 128 MB
- Supported Devices
- Hard drive, disk array (RAID)
- Channel Qty
- 8
- RAID Level
- RAID 0, RAID 1, RAID 10, JBOD, RAID 1E
- 15.5 cm x 6.4 cm
- 3-year warranty
- Host Bus
- PCIe x4
Storage Controller
- Interface
- 6 Gbit/s
- Buffer Size
- 128 MB
- Supported Devices
- Channel Qty
- 8
- RAID Level
- Processor
- PMC-Sierra PM8013
- 2 x SATA 6Gb/s / SAS 6Gb/s - 36 pin 4i Mini MultiLane (internal)
- Compatible Slots
- 1 x PCI Express x4 - low-profile
- Included Accessories
- Low-profile bracket
- Cables Included
- 2 x Serial ATA / SAS cable - 4 connectors - 70 cm
- MTBF
- 860,953 hours
- UL, VCCI, C-Tick, FCC, RoHS, KCC, WEEE, REACH
- Software Included
- Drivers & Utilities, Adaptec Storage Manager
- Limited warranty - 3 years
- 15.5 cm
- 6.4 cm
- 0 °C
- 55 °C
