Adaptec RAID 2405 ROHS Single Storage Controller
Quicklinx: 7XW8WS00 Mfr#: 2260200-R
For basic RAID functionality that is independent of the host and operating system, plus high bandwidth for I/O applications in a controller designed for entry-level storage solutions, choose Adaptec. The Adaptec RAID 2405 is equipped with the enhanced reliability of hardware RAID 0, 1 and 10, industry-leading dual core RAID on Chip (ROC) and 128MB of DDR2 cache.
Four internal ports in this Unified Serial controller allow you to connect up to 128 SATA/SAS devices through SAS expanders.
Adaptec Storage Manager provides one-view centralized management of all your Adaptec RAID controllers.
The Adaptec RAID 2405 also integrates the latest PCIe connectivity, the broadest operating system support, including open source Linux drivers, and proven compatibility.
Microchip Adaptec RAID 2405 - storage controller (RAID) - SATA 3Gb/s / SAS - PCIe x8
Storage controller (RAID) - plug-in card - low profile
Bus Type
PCIe x8
SATA 3Gb/s / SAS
Data Transfer Rate
3 Gbit/s
Buffer Size
128 MB
Supported Devices
Hard drive, disk array (RAID)
Channel Qty
4
RAID Level
RAID 0, RAID 1, RAID 10, JBOD
SCO OpenServer, UnixWare, FreeBSD, SUSE Linux Enterprise Server, Microsoft Windows Server 2003, Red Hat Enterprise Linux, SunSoft Solaris x86 10, Microsoft Windows Vista / XP, VMware ESX Server
Microsoft Certification
Works with Windows Vista
16.7 cm x 6.4 cm
3-year warranty
Host Bus
PCIe x8
Storage Controller
SATA 3Gb/s / SAS
Data Transfer Rate
3 Gbit/s
Buffer Size
128 MB
Supported Devices
Channel Qty
4
RAID Level
800 MHz
1 x SATA 3Gb/s / SAS - 36 pin 4i Mini MultiLane (internal)
Compatible Slots
1 x PCI Express x8 - low-profile
MTBF
873,402 hours
Software and devices that carry the Works with Windows Vista logo have been tested for baseline compatibility with PC's running.
UL, VCCI, C-Tick, FCC, RoHS
Software Included
Limited warranty - 3 years
16.7 cm
6.4 cm
55 °C
