Acronis True Image Home 2012 Family Pack - PC Backup & Recovery - Complete package - 3 PCs
Quicklinx: 7YGXWS00 Mfr#: TIHRXWUKS
In a split second, you could lose all your photos, videos, emails, programs, critical files and shortcuts. But thanks to Acronis True Image Home 2012, every bit of data can be recovered and your entire system can be restored to its original shape, quickly and easily.
So much can go wrong with your computer, such as accidental file deletions, system viruses and total hard-disk failures. Having a complete PC-backup solution is critical. Having one that's fast, effective and incredibly simple is even better!
  • The perfect image
    Recovering data is just half the battle. Returning your system to the way it was is another story. All those software downloads and program shortcuts you've added over the years. With Acronis' patented disk imaging and PC-cloning technology, every bit of information can be restored to its original shape in minutes - without having to reinstall any software application. You can also use the secure zone function to create a secure disk partition on your internal drive. That way you can recover your system easily at any moment, even if your operating system has failed.
  • Stay in sync
    If you have two or more PCs and want them to mirror a selection of files or folders, it's now possible. This version of Acronis True Image Home includes file synchronization, which lets you replicate important data between multiple computers, files or devices. Sync files with friends, family or colleagues over the web. Or sync with local folders, including USB sticks or external hard drives.
  • Always on schedule
    Setting up and running your backups is convenient with Acronis True Image Home. Smart scheduling offers you practical options to decide when your backups should run, like during idle times or just before startup or shutdown. Set&Forget lets you configure your backups just once and then the software does the remembering for you.
  • Flirt with danger
    Now it's easier to avoid disasters before they happen. For instance, if you want to try out new software but are not sure if it's virus-prone, Try&Decide lets you take a test drive first to see if you want to keep or discard the changes to your system. This is also very practical for browsing potentially dangerous websites.
  • Greater upgrade possibilities
    Take your Acronis experience to the next level with special plus pack add-on. This gives you advanced features, such as dynamic-disk support and universal restore, which lets you recover your entire system on a computer with a completely different architecture.
  • Round-the-clock reassurance
    Because you've got enough on your mind, Acronis True Image Home stays on top of the action to ensure you continuous data protection. Acronis nonstop backup performs ongoing incremental changes as you go, so, if needed, you can roll back your system, file or folder to a specific point in time. And thanks to live backups, you can keep on working with no interruption during backups.
  • Enter your image
    A full-system backup image isn't just a huge pile of ones and zeros. With Acronis' mount image feature, you can temporarily transform this image into a virtual drive, which lets you access and browse all your folders just like a real, physical drive. Drag and drop your files wherever you want without having to reboot or restore the image. It's like having direct access to your old system.
  • A boot in the right direction
    If ever your Operating System fails to boot and you don't want to fuss around with bootable CDs or flash drives to get back up and running, Acronis gives you a hand. With a simple touch of your F11 key, the Acronis startup recovery manager hops into gear and gets you into a fully functional recovery environment through which you can recover your entire system with ease.
  • Full speed ahead
    Your life is too busy to wait around for software to do its job. Acronis helps you keep backup and restoration time to a minimum. Acronis True Image Home saves you precious time thanks to its extremely simple design and convenient features. It also supports the latest USB 3.0 standard, which gives you high-speed data transfer for all your critical safeguards, whether file backup or full PC backup.
  • Travel through time
    Everyone makes mistakes. But with Acronis, you can always go back and do things differently. When running incremental backups, use Acronis' time explorer feature to travel back to a specific point in time and, via intuitive screen shots, view or recover your system and data exactly how it was at that moment.
Acronis True Image Home 2012 Family Pack - box pack - 3 PCs
Box pack
Category
Utilities - desktop backup / archiving, data recovery
Licence Qty
3 PCs
Platform
Windows
Language
English
Distribution Media
(mini-box)
Category
Box pack
Platform
Windows
Distribution Media
(mini-box)
Language
English
Licencing
Licence Qty
3 PCs
Supported OS
Microsoft Windows XP Professional SP2, Microsoft Windows XP Professional x64 Edition SP2, Microsoft Windows Vista (32/64 bits) SP2, Microsoft Windows XP Home Edition SP3, Microsoft Windows 7 (32/64 bits)
Hardware Requirements
Microsoft Windows - Pentium - 1 GHz - RAM 512 MB
Additional Requirements
Mouse or compatible device, CD-RW, DVD-RW, Internet connection
