An incredible resolution and a curved 21:9 aspect ratio widescreen give you a truly panoramic view. Easy adjustments and special picture modes allow you to fully customize your viewing experience.
Flickerless technology
Reduces annoying screen flickering that can cause eye strain when viewing the monitor for long periods. -
21:9 aspect ratio
Get all the benefits of Full HD in an ultra-wide format. Superb for movies and for viewing documents side by side. -
USB 3.0
Easily transfer text and data files, photos and even movies at faster speeds.
- Acer XR382CQK - LED monitor - curved - 37.5"
- LED-backlit LCD monitor - 37.5"
- Energy Class
- Class B
- Energy Consumption per Year
- 85 kWh
- Power Consumption (On mode)
- 58 W
- Curved Screen
- Daisy Chaining
- USB 3.0 hub
- Panel Type
- IPS
- Aspect Ratio
- 21:9
- Native Resolution
- 3840 x 1600 at 75 Hz
- Pixel Pitch
- 0.229 mm
- Brightness
- 300 cd/m²
- Contrast Ratio
- 100000000:1 (dynamic)
- Response Time
- 5 ms (grey-to-grey)
- Colour Support
- 1.07 billion colours
- Colour Gamut
- 100% sRGB
- Input Connectors
- HDMI, HDMI (MHL), DisplayPort, Mini DisplayPort
- Height, swivel, tilt
- Screen Coating
- Anti-glare
- Voltage
- AC 120/230 V (50/60 Hz)
- Silver
- Image Colour Disclaimer
- The displayed product image may be a different colour
- 89.688 cm x 30.9 cm x 46.177 cm
- 10.9 kg
- Display Type
- Energy Class
- Class B
- 85 kWh
- Diagonal Size
- 37.5"
- Curved Screen
- Daisy Chaining
- Built-in Devices
- USB 3.0 hub
- Panel Type
- IPS
- Aspect Ratio
- 21:9
- Native Resolution
- Pixel Pitch
- 0.229 mm
- Brightness
- 300 cd/m²
- Contrast Ratio
- Colour Support
- Colour Gamut
- 100% sRGB
- Response Time
- Horizontal Viewing Angle
- 172
- Vertical Viewing Angle
- 178
- Screen Coating
- Anti-glare
- Backlight Technology
- LED backlight
- Picture in picture, ambient light sensor, picture by picture, Acer EcoDisplay, Zero Frame, Flicker-Less technology, Blue Light Filter technology, DTS Sound, Adaptive-Sync technology
- Silver
- 89.688 cm x 30.9 cm x 46.177 cm - with stand
- 10.9 kg
Audio
- Speakers - stereo
- Output Power / Channel
- 7 Watt
- HDMI , MHL / HDMI , DisplayPort , DisplayPort output , Mini DisplayPort , USB 3.0 upstream , 4 x USB 3.0 downstream
Mechanical
- Tilt Angle
- -5/+35
- Swivel Angle
- 60
- Height Adjustment
- 130 mm
- Included Accessories
- Stand
- Cables Included
- 1 x DisplayPort cable , 1 x SuperSpeed USB cable
- Input Voltage
- 58 W
- Power Consumption (Typical)
- 58 Watt
- Power Consumption Sleep
- 0.5 Watt
- 0.48 Watt
