Acer XF240YUbmiidprzx 23.8" 2560x1440 4ms DVI HDMI DP Monitor
UP TO A POSSIBLE £200 CASHBACK AVAILABLE - SEE PRODUCT FOR MORE INFO
Cashback
Quicklinx: CP8HWS00 Mfr#: UM.QX0EE.001
Acer XF240YU - LED monitor - 23.8"
LED-backlit LCD monitor - 23.8"
Energy Class
Class B
Energy Consumption per Year
62 kWh
Adaptive-Sync Technology
AMD FreeSync
USB 3.0 hub
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
2560 x 1440 at 144 Hz
Brightness
350 cd/m²
Contrast Ratio
100000000:1 (dynamic)
Input Connectors
2xHDMI, DVI-D, DisplayPort
Display Position Adjustments
Height, pivot (rotation)
Screen Coating
Anti-glare
54.1 cm x 24.4 cm x 37.5 cm
Display Type
Energy Class
Class B
62 kWh
Diagonal Size
23.8"
AMD FreeSync
Built-in Devices
USB 3.0 hub
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
Brightness
350 cd/m²
Contrast Ratio
Screen Coating
Anti-glare
Backlight Technology
LED backlight
Acer EcoDisplay
DVI-D (dual link) , 2 x HDMI , DisplayPort , 4 x USB 3.0 downstream , USB 3.0 upstream , Audio line-in/out
Mechanical
VESA Mounting Interface
100 x 100 mm
VESA interface support
Limited warranty - 2 years - carry-in
