A rapid 144 Hz refresh rate and a blazing-fast 1 ms response time deliver ultra-smooth motion scenes. The lower latency and immersive graphics will vastly improve your gaming experience.
The Acer ErgoStand lets the XB0 series pivot, tilt, swivel and move up or down, so you can find the most comfortable view to focus on dodging your foes.
Acer ComfyView technology enables you to stay in the battle longer by reducing glare to provide less eye strain.
Charge
A rapid 144 Hz refresh rate and a blazing-fast 1 ms response time deliver ultra-smooth motion scenes. The lower latency and immersive graphics will vastly improve your gaming experience. -
Find the most comfortable view
The Acer ErgoStand lets the XB0 series pivot, tilt, swivel and move up or down, so you can find the most comfortable view to focus on dodging your foes. -
Never back down
- Acer XB270H - LED monitor - Full HD (1080p) - 27"
- LED-backlit LCD monitor - 27"
- Energy Class
- Class B
- Energy Consumption per Year
- 55 kWh
- USB 3.0 hub
- Panel Type
- TN
- Aspect Ratio
- 16:9
- Native Resolution
- Full HD (1080p) 1920 x 1080 at 144 Hz
- Pixel Pitch
- 0.311 mm
- Brightness
- 300 cd/m²
- Contrast Ratio
- 100000000:1 (dynamic)
- Response Time
- 1 ms
- Colour Support
- 16.7 million colours
- Colour Gamut
- 72% NTSC
- Input Connectors
- HDMI, MHL, DVI, DisplayPort, VGA
- Height, pivot (rotation), swivel, tilt
- Voltage
- AC 120/230 V
- Black glossy with orange ring on footstand
- 64 cm x 24.7 cm x 40.8 cm
- 7.9 kg
- Microsoft Certification
- Compatible with Windows 7
- Environmental Standards
- ENERGY STAR Qualified
- MPR II, TUV, GS, ISO9241-307
- 2-year warranty
- Display Type
- Energy Class
- Class B
- 55 kWh
- Diagonal Size
- 27"
- Built-in Devices
- USB 3.0 hub
- Panel Type
- TN
- Aspect Ratio
- 16:9
- Native Resolution
- Pixel Pitch
- 0.311 mm
- Brightness
- 300 cd/m²
- Contrast Ratio
- Colour Support
- Colour Gamut
- 72% NTSC
- Response Time
- 1 ms
- Horizontal Viewing Angle
- 176
- Vertical Viewing Angle
- 170
- Backlight Technology
- LED backlight
- ErgoStand, Acer EcoDisplay, ComfyView, Hard Coating (3H), 72% NTSC colour gamut
- 7.9 kg
- DisplayPort , USB 3.0 upstream , 4 x USB 3.0 downstream , DVI , HDMI , VGA
Mechanical
- Tilt Angle
- -5/+35
- Swivel Angle
- 120
- Rotation Angle
- 90
- Height Adjustment
- 150 mm
- VESA Mounting Interface
- 100 x 100 mm
- Cables Included
- 1 x DisplayPort cable , 1 x SuperSpeed USB cable
- MTBF
- 30,000 hour(s)
- Power Supply
- Internal
- Input Voltage
- AC 120/230 V
- Power Consumption (Typical)
- 26.5 Watt
- Power Consumption Stand by
- 500 mW
- Power Consumption Sleep
- 450 mW
Sustainability Information
- ENERGY STAR Certified
- Limited warranty - 2 years
