Stand out from the crowd with the bright X series projector. The Acer X1326WH is the world 1st projector equipped with blue light filter. The series features 4,000 lumens high brightness and LumiSense that give your presentation a clearer, sharp edge. Project the future of business meeting. Acer present to you the world 1st projector equipped with blue light filter on X1 series. Acer Bluelight shield allows users to lower levels of blue light to lessen the negative effects of blue light exposure. There are three levels of filter in projector suitable for different scenario. Each level also contains dynamic mechanism that will optimize the blue light level based on content. Bluelight shield can reduces up to 30% blue light and protect your eyes.
- Acer X1326WH - DLP projector - portable - 3D
- DLP projector - 720p
- 3D Capable
- Yes (3D glasses sold separately)
- Built-in Devices
- Speaker
- Microdisplay
- DarkChip 3
- Brightness
- 4000 ANSI lumens
- Contrast Ratio
- 20000:1 (dynamic)
- Resolution
- WXGA (1280 x 800)
- Native Aspect Ratio
- 16:10
- Colour Support
- 1.07 billion colours
- Bulb type
- UHP 220 Watt
- Bulb life cycle
- Up to 4500 hour(s) - normal mode , Up to 15000 hour(s) - economic mode
- Video Input
- RGB, S-Video, composite video (PAL-B/G, PAL-N, PAL-M, PAL-I, NTSC 4.43, NTSC 3.58, PAL-D, SECAM L, PAL-H, SECAM K1, SECAM D/K, SECAM B/G)
- Video Modes
- 480p, 720p, 1080i, 1080p, 480i, 576i, 576p
- Speakers
- Speaker(s) - integrated
- Power
- AC 120/230 V
- 260 Watt
- 31.5 cm x 21.4 cm x 9.8 cm
- 2.6 kg
- 3D Capable
- Built-in Devices
- Speaker
Projector
- Microdisplay
- DarkChip 3
- Brightness
- 4000 ANSI lumens
- Brightness (Reduced)
- 3200 ANSI lumens
- Contrast Ratio
- 20000:1 (dynamic)
- Image Size
- 69 cm - 762 cm
- Projection Distance
- 1 m - 10 m
- Throw Ratio
- 1.54 - 1.72:1
- Uniformity
- 85 %
- Digital Zoom Factor
- 2x
- Resolution
- WXGA - WXGA (1280 x 800) (native) / 1920 x 1200 (resized)
- 16:10
- Colour Support
- Max Sync Rate (V x H)
- 120 Hz x 100 kHz
- Bulb type
- UHP 220 Watt
- Bulb life cycle
- DLP 3D Ready, SmartFormat Technology, 16:9 aspect ratio support, EcoProjection Technology, 4:3 aspect ratio support, Acer ColorSafe II Technology, MHL compliance, Quick-Start, ColorBoost 3D Technology, Acer LumiSense+
Lens
- Focus Type
- Manual
- Lens Aperture
- F/2.5-2.67
- Zoom Type
- Manual
- Zoom Factor
- 1.1x
- Keystone Correction Direction
- Vertical
- Vertical Keystone Correction
- -40 / +40
Video Input
- TV System
- PAL-B/G, PAL-N, PAL-M, PAL-I, NTSC 4.43, NTSC 3.58, PAL-D, SECAM L, PAL-H, SECAM K1, SECAM D/K, SECAM B/G
- Analogue video Signal
- Video Interfaces
- VGA, HDMI, composite video, S-Video, MHL
- Video Modes
Speakers
- Integrated
- Sound Output Mode
- Mono
- Output Power / Channel
- 3 Watt
- Speakers
- 1 x mixed channel
- 1 x VGA output - 15 pin HD D-Sub (HD-15) , 1 x composite video input - RCA , 1 x S-video input - 4 pin mini-DIN , 2 x component video / RGB input - 15 pin HD D-Sub (HD-15) , 1 x HDMI - 19 pin HDMI Type A , 1 x Mobile High-Definition Link (MHL) / HDMI , 1 x USB - 4 pin USB Type A , 1 x serial RS-232 - 9 pin D-Sub (DB-9) (management) , 2 x audio line-in - mini-phone stereo 3.5 mm , 1 x audio line-out - mini-phone stereo 3.5 mm
- Included Accessories
- Wireless remote control
- Cables Included
- 1 x VGA cable
- Power Source
- AC
- Voltage Required
- AC 120/230 V
- 260 Watt
- 31.5 cm
- 21.4 cm
- 9.8 cm
- 2.6 kg
- 0 °C
- 40 °C
- Sound Emission
- 32 dBA
- Sound Emission (Economic Mode)
- 24 dBA
