Vivid color display
With support for 1.07 billion colors and a high contrast ratio of 20,000:1, the Acer X128H delivers a stunning visual experience, making every presentation come to life. -
Long-lasting performance
The projector's lamp offers a life cycle of up to 4000 hours in normal mode and up to 10,000 hours in economic mode, ensuring reliable performance for countless presentations. -
Flexible connectivity
Equipped with a variety of interfaces including HDMI, VGA, and composite video inputs, the Acer X128H provides versatile connectivity options for a wide range of multimedia devices. -
Enhanced portability
Designed with portability in mind, this lightweight and compact projector is ideal for professionals on-the-go, offering easy setup and quick adjustments for any presentation environment. -
3D ready
The Acer X128H is DLP 3D Ready, offering an immersive 3D viewing experience for presentations, videos, and educational content, making it a versatile tool for engaging audiences.
- Acer X128H - DLP projector - portable - 3D
- DLP projector
- 3D Capable
- Yes (3D glasses sold separately)
- Brightness
- 3600 ANSI lumens
- Contrast Ratio
- 20000:1
- Resolution
- XGA (1024 x 768)
- Native Aspect Ratio
- 4:3
- Colour Support
- 1.07 billion colours
- Bulb type
- P-VIP 203 Watt
- Bulb life cycle
- Up to 4000 hour(s) - normal mode , Up to 10000 hour(s) - economic mode
- Video Input
- RGB, composite video
- Speakers
- Speaker(s) - integrated
- Power
- AC 120/230 V
- 240 Watt
- 31.3 cm x 24 cm x 11.37 cm
- 2.7 kg
- DLP projector
- 3D Capable
Projector
- Brightness
- 3600 ANSI lumens
- Brightness (Reduced)
- 2880 ANSI lumens
- Contrast Ratio
- 20000:1
- Image Size
- 58 cm - 762 cm
- Projection Distance
- 1 m - 11.8 m
- Throw Ratio
- 1.94 - 2.16:1
- Digital Zoom Factor
- 2x
- Resolution
- XGA - XGA (1024 x 768) (native) / 1920 x 1200 (resized)
- 4:3
- Colour Support
- Max Sync Rate (V x H)
- 120 Hz x 100 kHz
- Bulb type
- P-VIP 203 Watt
- Bulb life cycle
- 6-segment colour wheel, DLP 3D Ready, SmartFormat Technology, 16:9 aspect ratio support, EcoProjection Technology, Auto Power Off, Acer ColorSafe II Technology, Quick-Start, ColorBoost 3D Technology, Acer LumiSense, Acer Bluelight Shield
Lens
- Focus Type
- Manual
- Lens Aperture
- F/2.41-2.53
- Zoom Type
- Manual
- Zoom Factor
- 1.1x
- Keystone Correction Direction
- Vertical
- Vertical Keystone Correction
- -40 / +40
Video Input
- Analogue video Signal
- Video Interfaces
- VGA, HDMI, composite video
Speakers
- Integrated
- Sound Output Mode
- Mono
- Output Power / Channel
- 3 Watt
- Speakers
- 1 x mixed channel
- 1 x USB - 4 pin USB Type A , 1 x composite video input - RCA , 1 x VGA input - 15 pin HD D-Sub (HD-15) , 1 x HDMI - 19 pin HDMI Type A , 1 x audio line-in - mini-phone 3.5 mm
- Included Accessories
- Lens cover, wireless remote control
- Cables Included
- 1 x VGA cable
- FCC, ROSTEST
- Power Source
- AC
- Voltage Required
- AC 120/230 V
- 240 Watt
- 31.3 cm
- 24 cm
- 11.37 cm
- 2.7 kg
- Shipping Width
- 40 cm
- Shipping Depth
- 34 cm
- Shipping Height
- 16.8 cm
- Shipping Weight
- 3.81 kg
- 0 °C
- 40 °C
- 80%
- Sound Emission
- 30 dBA
- Sound Emission (Economic Mode)
- 24 dBA
