With high resolution, high brightness, high contrast and Acer Color technology, your presentations will be more compelling with sharper texts and vibrant images, even from a distance. The accumulation of dust over time can cause a projector to not function properly and lose its original brightness. With Acer Dust Shield, Essential series projectors can defend against the detrimental effects of dust, allowing them to work better, for longer, and requiring less maintenance. Essential series projectors have features that make them easy to use.
Bright and vivid
With high resolution, high brightness, high contrast and Acer Color technology, your presentations will be more compelling with sharper texts and vibrant images, even from a distance. -
Acer Dust Shield
The accumulation of dust over time can cause a projector to not function properly and lose its original brightness. With Acer Dust Shield, Essential series projectors can defend against the detrimental effects of dust, allowing them to work better, for longer, and requiring less maintenance. -
Convenient and flexible
- Acer X118 - DLP projector - portable - 3D
- DLP projector
- 3D Capable
- Yes (3D glasses sold separately)
- Brightness
- 3600 lumens
- Contrast Ratio
- 20000:1 (dynamic)
- Resolution
- SVGA (800 x 600)
- Native Aspect Ratio
- 4:3
- Bulb type
- 203 Watt
- Bulb life cycle
- Up to 4000 hour(s) - normal mode , Up to 10000 hour(s) - economic mode
- Video Input
- RGB
- 31.3 cm x 24 cm x 11.37 cm
- 2.7 kg
- DLP projector
- 3D Capable
Projector
- Brightness
- 3600 lumens
- Brightness (Reduced)
- 2800 lumens
- Contrast Ratio
- 20000:1 (dynamic)
- Throw Ratio
- 1.94 - 2.16:1
- Resolution
- SVGA - SVGA (800 x 600) (native) / 1920 x 1200 (resized)
- 4:3
- Bulb type
- 203 Watt
- Bulb life cycle
- DLP 3D Ready, 16:9 aspect ratio support, EcoProjection Technology, DynamicBlack technology, Acer ColorSafe II Technology, ColorBoost 3D Technology, ExtremECO, Acer LumiSense, Acer Bluelight Shield
Lens
- Focus Type
- Manual
- Lens Aperture
- F/2.41-2.53
- Zoom Type
- Manual
- Keystone Correction Direction
- Vertical
- Vertical Keystone Correction
- -40 / +40
Video Input
- Analogue video Signal
- RGB
- Video Interfaces
- VGA
- 1 x component video / RGB input - 15 pin HD D-Sub (HD-15) , 1 x USB - 4 pin USB Type A
- Included Accessories
- Lens cover, remote control
- Cables Included
- 1 x VGA cable
- 31.3 cm
- 24 cm
- 11.37 cm
- 2.7 kg
- Sound Emission
- 33 dBA
- Sound Emission (Economic Mode)
- 27 dBA
