With high resolution, high brightness, high contrast and Acer color technology, your presentations will be more compelling with sharper texts and vibrant images, even from a distance. Combined with DLP 3D ready you can also enjoy an immersive theater-like 3D entertainment experience.
Acer Dust Shield
The accumulation of dust over time can cause a projector to not function properly and lose its original brightness. With Acer Dust Shield, this projector can defend against the detrimental effects of dust, allowing it to work better, for longer, and requiring less maintenance. -
Convenient and flexible
The projector has features, that make it easy to use, including 9-key control panel on the top of the projector and 40-degree keystone correction, that automatically adjusts vertical distortions. Its ceiling mounts provide four ways to install them, so you can pick the method that optimally suits your needs. -
Eco-smart
The projector sports eco-friendly technologies, that are better for the planet and good for your wallet. Its standby power consumption can be reduced, when powered on, which helps to prolong the lifespan of its lamps for lower replacement costs.
- Acer X115H - DLP projector - portable - 3D
- DLP projector
- 3D Capable
- Yes (3D glasses sold separately)
- Microdisplay
- DarkChip 3
- Brightness
- 3300 ANSI lumens
- Contrast Ratio
- 20000:1 (dynamic)
- Resolution
- SVGA (800 x 600)
- Native Aspect Ratio
- 4:3
- Colour Support
- 1.07 billion colours
- Bulb type
- P-VIP 195 Watt
- Bulb life cycle
- Up to 5000 hour(s) - normal mode , Up to 10000 hour(s) - economic mode
- Video Input
- RGB (PAL-B/G, PAL-N, PAL-M, PAL-I, NTSC 4.43, NTSC 3.58, PAL-D, SECAM L, PAL-H, SECAM K1, SECAM D/K, SECAM B/G)
- Video Modes
- 480p, 720p, 1080i, 1080p, 480i, 576i, 576p
- Power
- AC 120/230 V
- 235 Watt
- 31.4 cm x 22.3 cm x 9.3 cm
- 2.5 kg
- DLP projector
- 3D Capable
Projector
- Microdisplay
- DarkChip 3
- Brightness
- 3300 ANSI lumens
- Brightness (Reduced)
- 2640 ANSI lumens
- Contrast Ratio
- 20000:1 (dynamic)
- Image Size
- 69 cm - 762 cm
- Projection Distance
- 1.2 m - 11.8 m
- Throw Ratio
- 1.94 - 2.16:1
- Uniformity
- 85 %
- Digital Zoom Factor
- 2x
- Resolution
- SVGA - SVGA (800 x 600) (native) / 1920 x 1200 (resized)
- 4:3
- Colour Support
- Max Sync Rate (V x H)
- 120 Hz x 100 kHz
- Bulb type
- P-VIP 195 Watt
- Bulb life cycle
- Instant Pack Technology, DLP 3D Ready, SmartFormat Technology, 16:9 aspect ratio support, EcoProjection Technology, 24p True Cinema, Acer ColorSafe II Technology, Quick-Start, ColorBoost 3D Technology, ExtremECO
Lens
- Focus Type
- Manual
- Lens Aperture
- F/2.41-2.53
- Zoom Type
- Manual
- Zoom Factor
- 1.1x
- Keystone Correction Direction
- Vertical
- Vertical Keystone Correction
- -40 / +40
Video Input
- TV System
- PAL-B/G, PAL-N, PAL-M, PAL-I, NTSC 4.43, NTSC 3.58, PAL-D, SECAM L, PAL-H, SECAM K1, SECAM D/K, SECAM B/G
- Analogue video Signal
- RGB
- Video Interfaces
- VGA, HDMI
- Video Modes
- 1 x component video / RGB input - 15 pin HD D-Sub (HD-15) , 1 x HDMI - 19 pin HDMI Type A , 1 x audio line-in - mini-phone 3.5 mm , 1 x USB - 4 pin mini-USB Type B
- Included Accessories
- Wireless remote control
- Cables Included
- 1 x VGA cable
- Power Source
- AC
- Voltage Required
- AC 120/230 V
- 235 Watt
- Power Consumption Stand by
- 0.5 Watt
- 31.4 cm
- 22.3 cm
- 9.3 cm
- 2.5 kg
- 0 °C
- 40 °C
- Sound Emission
- 34 dBA
- Sound Emission (Economic Mode)
- 31 dBA
